Trade: ELECTRICAL REMODELING
Low Voltage Cans
how many low voltage cans per 20 amp circuit?
Electrical Contractor
Trade: Electrical
Re: Low Voltage Cans
Seriously?
What wattage are the cans rated for?
Trade: Squirrel Handler
5 x the number of stairs between landings from the first floor to second, if no stairs, no limit.
Three.
What do I win? |
Trade: Electrical
I was wondering if it was a trick question.
Not so many resi 20 amp lighting circuits, in my observation anyhow. Mostly commercial work, where you'd run 20 amp lighting circuits.
To the OP, wattage is important. If you had 1 watt cans, you could run a couple thousand on a 20 amp circuit. If you had 50 watt cans, maybe only 40 or so. |
That's about right, 40, I have 8 stairs between landings, so 8 x 5 = 40.
Re: Low Voltage Cans |
I hope this guy doesn't have high ceilings and about 16 steps.
Union Electrician
Trade: Inside Wireman
Wait if they're low voltage, assuming 12 volts, you can have 10,000,000 12 volt lights on a 120 volt circuit, or somewhere around there. Amps, that's a different story, you give 20 as an output but what's the input(current -or- wattage with voltage of the lamps)?
I never understood the desire for a low voltage fixture? Do people think that because they can stick their finger in the socket with no shock then they're really getting something high end? For energy efficiency think higher voltages. It still takes the same amount of power to move the same pile of crap, but your line losses are lower. Meaning your not losing as much power simply trying to get the power to the load. |
| High Voltage vs Low Voltage Lights | robertc65 | Outdoor Lighting | 16 | 04-04-2011 06:26 AM |
| Universal voltage ballast | K2 | Electrical | 25 | 12-05-2007 04:25 AM |
| Can I provide flood lighting via Low Voltage | robertc65 | Outdoor Lighting | 8 | 11-06-2007 10:42 AM |
| cat5 voltage | jdeihs | Low Voltage | 7 | 06-17-2007 03:26 PM |
| Voltage Sag mp3 | Magnettica | Electrical | 2 | 03-08-2007 06:39 PM |
