Plumber / Carpenter
Low Amps Kills Skill Saw?
Am framing a house. Its an addition. Breakers seem to make a "Sizzle" noise after about 6 hours of use. My skill saw will not run now. Can this be a result of inadequate amps running the saw?
#2 | |
DGFVT
Trade: Electrical
Re: Low Amps Kills Skill Saw?Quote:
Someone will come along with a extension cord sizing chart.
Plumber / Carpenter
Could had been. We use a extension no longer than 10 foot and very heavy gauge for the compressor, the skill saw was plugged into probably a 50' cord from Lowe's (Home Owners)
That'll do it every time. Voltage drop kills saws. Run really heavy cords for your saws. It seems silly, I know, to spend 100 bucks on a 50 foot extension cord, but you really need to. Probably should have been a 10 guage cord for that length, but the homeowner's cord was more than likely 16 gauge.
Handle It!
This might help.
http://nevadawalrus.com/index-wired.html As it has been posted in other threads...ALWAYS over gauge and over rate the load you have. One can NEVER go wrong that way!! And when your work site begins to resemble this... ![]() then it is time to reevaluate! This is next............When you ignore proper load!
Something to One may be Nothing to another! Ultimate Wisdom--------- http://www.youtube.com/watch?v=OW-cnizLDEE Last edited by MALCO.New.York; 08-17-2008 at 07:42 PM. |
#6 | |
Plumber / Carpenter
Re: Low Amps Kills Skill Saw? |
Plumber / Carpenter
I am MD, I am going to buy a new one. Figure its cheaper and faster.
I often thought I could build a little box for pretty cheap that would just shut the power off if there was too much voltage drop, but I doubt anyone would buy it. The saw manufacturers could make a pretty small circuit to put in the saw's handle to shut off the power and preserve the saw, but it would probably just tick people off. A few cuts with extreme voltage drop is no big deal. Working all day is a pretty big deal.
#10 | |
Handle It!
Kinda like GM could make a car that lasted 3 million miles and a carburetor/detonation configuration that allowed 200 MPG. It is all about the bottom line.
#11 | |
Service Plumber
Trade: Plumber
That first pic looks like a still shot out of "I AM Legend"
"To think for yourself you must question authority and learn how to put yourself in a state of vulnerable, open-mindedness; chaotic, confused, vulnerability to inform yourself. Think for yourself. Question authority". .. |
Handle It!
Google images.
Electrician
Trade: Electrical Contractor
I ran into a good one. I was about to drill the studs on the second floor. I found a heavy duty cord already hanging up there. It had a 20 amp 120 volt connector body on it. Lucky me.
I plugged in my short extension cord and drill and squeezed the trigger. Fire shot out of the drill and it made a noise and smell that is very hard to miss. Seems that cord was wired into the panel for 240 volts for a large barn fan the carpenters had up there in the heat. ![]() The new drill had less than 2 hours on it when I did this. It is still working fine on 120 volts thank goodness. Why would they use the proper connector body and plug? They knew not to plug their saws into that cord.
John |
#15 | |
The Remodeler
Trade: Home Remodeler
Electrician
Well I'm glad I'm not the only one.
John |
![]() Trade: student again
A cord someone has sitting around is usually 16AWG, if not 18. 50' extension cord for running a circular saw on 120v should be 12AWG.
#18 |
Al Smith
Two things that will kill saws guaranteed. low amps. dull blades.
#19 |
The Remodeler
Kills compressors too... Customers home had a lot of DIY wiring... I plugged the trailers compressor into the garage outlet with my heavy duty cord and it ran sluggish... We were so busy and I just wanted to get this job done, so I left it as is... Second day the compressor burned out. Turns out that garage outlet was at the end of an almost 400' run of 14-2 romex. Half the house was on that circuit.
| Skill saws for framing | hrscammisa | Framing | 80 | 12-04-2008 04:57 AM |
| Adding 400 amps to Commercial Bldg | Bubbles | Electrical | 10 | 08-22-2008 06:39 AM |
| New Employee Skill Assessment Test!!! | Harmoney Const | Carpentry | 68 | 08-19-2008 01:35 AM |
| volt amps vs watts | Bkessler | Electrical | 10 | 11-26-2006 05:21 PM |
| Modifying a Skill 2972 Cordless Screwdriver | slickshift | Tools & Equipment | 4 | 06-09-2006 02:03 PM |
