Trade: framing contractor
Lost A Phase
Lost a phase on the 600 volt service in my brother in law's shop. Turns out a fuse was blown. Replaced it and it blew again even though I isolated everything outside the splitter box. Called in my electrician and he can't figure it out. Three electricians and me stood there not being able to figure out whats wrong. All the safety switches coming off the splitter are shut off and there is no problems coming from the safety switch to the splitter and no problems in the splitter it self. Has anybody heard of anything like this?
LRG WoodCrafting
Re: Lost A Phase
Did you check to see that the fuseholder hasn't somehow grounded out on the box?
#3 | |
Trade: Electrical & Carpentry
Re: Lost A PhaseQuote:
woodchuck2
Re: Lost A Phase
X3, i agree with the short to ground. Where is easy enough to verify with a meter. Time to tear into it IMO.
Fentoozler
Re: Lost A Phase
Haphazardly replacing a fuse w/o identifying the actual the actual problem is a sure way to maintain the failure ~ or worse.
Find the source of the short and/over current and remedy the situation before blowing up any more fuses ~ or worse.
Trade: Electrician
Re: Lost A Phase
Has anyone tried using a Megger? I bet you'd find the problem in no time at all...
Re: Lost A Phase
Usually in a case like this one you only need your ohmeter to find the problem. I personally have used a meggar hundreds of times on high voltage cables & equiptment. The meggar isn't going to pinpoint the problem any quicker than an ohmeter. You still have to "dig" into it to find out what the short actually is. The meters are just a tool to help you do that........................
Trade: Railing
Re: Lost A Phase
Considering it's 600 volts, couldn't you have a condition where you wouldn't get a reading with an ohmeter, but could arc under voltage? It's a common occurance with car ignition coils. At 600v the insulation value only needs to be reduced, so as to allow arcing. I'd start by breaking down the box's. If no arc damage is visable, it has to be in the conduit feed to the safety disconnect. It seems like there would be some burnt odor involved at some point.
Joe |
#9 | |
| Calls to previous lost opportunities!! | marketingchick | Marketing & Sales | 14 | 07-08-2009 10:04 PM |
| 3 phase setup | nivek | Electrical | 8 | 03-28-2009 07:05 PM |
| Lost a project today........ | Blas | Excavation & Site Work | 22 | 12-29-2008 03:38 PM |
| reverse for split phase motor | protechplumbing | Electrical | 7 | 10-28-2008 09:50 PM |
| 3 Phase calculation HELP | southern elec | Electrical | 10 | 06-13-2007 11:24 AM |
