Line V. Relay W/ Low V. Coil
Old 04-25-2007, 04:11 PM   #1
Rugger's Avatar
Trade: Electronic Systems Contractor
I need to find a reasonably priced relay to switch 240v load. (EWH) Control Voltage is 12 or 24 VDC. Need a relay that has a partition or enclosure to isolate hi & lo voltages. Without costing a fortune. Is anyone familiar with a relay similar to door bell XFMR's, where the low voltage connection is on the exterior of the box and the line voltage connection is inside the box? Maybe my next invention?
Rugger is offline
Old 04-25-2007, 05:13 PM   #2
mdshunk's Avatar
Re: Line V. Relay W/ Low V. Coil
A barrier is not required when both high and low voltage serves the same device, such as the contactor in this case. For an EWH, one of these babies ought to do the trick, for 15 dollars:
http://www.grainger.com/Grainger/items/5YZ74
And, the enclosure to put it in, for 7 dollars:
http://www.grainger.com/Grainger/items/4A079
mdshunk is offline
Old 04-25-2007, 07:34 PM   #3
jbwhite's Avatar
Trade: Electrician
1/4 inch seperation is required between the line and low volt wires. If the low volt is a class two or three source.
jbwhite is offline
Old 04-25-2007, 08:27 PM   #4
mdshunk's Avatar
Where you you read that?
mdshunk is offline
Old 04-25-2007, 09:18 PM   #5
jbwhite's Avatar
Trade: Electrician
725.55 (d)
jbwhite is offline
Old 04-25-2007, 11:35 PM   #6
Rugger's Avatar
Thanks for the replies. I thought it was a new requirement to isolate low v from high. But I have been unable to find it. Problem solved.
Rugger is offline
Old 04-25-2007, 11:37 PM   #7
Service & Repairs
Magnettica's Avatar
Trade: Electrician
725.55 (d)
Learn something new everyday!
Magnettica is offline
Old 04-26-2007, 01:45 AM   #8
DGFVT
CE1's Avatar
Trade: Electrical
My personal favorite.
http://www.grainger.com/Grainger/items/5LE35
Attachment 5335
CE1 is offline
Old 04-26-2007, 05:32 AM   #9
jbwhite's Avatar
Trade: Electrician
Originally Posted by CE1 View Post
Those relays have thier place. 715.52 (A) Exception No. 2
jbwhite is offline
Old 04-26-2007, 10:46 AM   #10
DGFVT
CE1's Avatar
Trade: Electrical
725.52 (A) Exception No. 2
CE1 is offline
Old 04-26-2007, 07:02 PM   #11
jbwhite's Avatar
Trade: Electrician
oops sorry for the mistype...
What is your point CE1, or do you not know either?
jbwhite is offline
Old 04-27-2007, 06:20 AM   #12
DGFVT
CE1's Avatar
Trade: Electrical
Nope not a clue. Just by deductive reasoning I noticed your numbers were "off". I treat the codebook as a minimun guide and not as absolute.
Carry On!
CE1 is offline
Old 04-28-2007, 12:03 AM   #13
747's Avatar
725.55 (d)
Your my hero
Ps. Maybe not i missed the post above is the code correct or not?
747 is offline
Old 04-28-2007, 06:32 AM   #14
jbwhite's Avatar
Trade: Electrician
725 is the correct article. but no applause, just send money..
jbwhite is offline
Old 04-28-2007, 10:36 AM   #15
jbwhite's Avatar
Trade: Electrician
CE1
I apologize. I just re-read my post and it sounds offensive. I meant it to be funny. I will be more carefull in the future.
jbwhite is offline
Old 04-28-2007, 01:07 PM   #16
DGFVT
CE1's Avatar
Trade: Electrical
CE1
No problem.
Here is your money. Attachment 5353
Carry On!
CE1 is offline
Old 04-28-2007, 01:58 PM   #17
jbwhite's Avatar
Trade: Electrician
No problem.
Hey, My bank won't take confederate states of america money...
jbwhite is offline
Old 04-28-2007, 10:28 PM   #18
DGFVT
CE1's Avatar
Trade: Electrical
Try this then, Never leave home without them!!
Attachment 5358
CE1 is offline
Old 05-14-2007, 09:28 PM   #19
sparkysteve's Avatar
Trade: Electrical
You guys ever use these? RIB "relay in a box"
I used to work for a control contractor. We used these to operate stuff like exaust fans, electric dampers, motors, lighting, etc off digital low voltage control panels. They mount to a box on a 1/2" K.O. The low voltage stays seperate from the line voltage. Available in every configuration you can think of.
They are from http://www.functionaldevices.com/
Steve
Master Electrician/Self-Proclaimed Handy-Man
sparkysteve is offline
Shingles Nailed Above Nail Line.. Help!! Unregistered Roofing 24 04-20-2011 09:14 PM
Straight Horizontal Line Speer007 Carpentry 17 12-15-2006 06:26 PM
cutting a line on an outside corner Traditions Painting & Finish Work 17 11-27-2006 09:03 AM
Replacing residential sewer line threequez Plumbing 1 10-17-2006 05:09 AM
Steel/vinyl coil stock. What to look for.. GiantScale Roofing 2 04-13-2006 07:38 PM
