Light Switch Into An Outlet??
Old 07-27-2008, 02:15 AM   #1
"Your not done yet!!??"
Green Machine's Avatar
Trade: Framming/siding/millwork
Is there a way to turn a light switch that is no longer used into an outlet? How tough is this. The light that the switch controlled before is now controlled by a differant switch. But where the old switch is, i need an outlet. figured it would save time if there was a safe way to convert.
Green Machine is offline
Old 07-27-2008, 02:41 AM   #2
Timster's Avatar
Trade: General
Re: Light Switch Into An Outlet??
If you have a neutral pigtailed through the box, then you should be able to cap the light leg, and use the 'hot' and neutral for a new outlet.
If you don't have a neutral, then I am afraid you are out of luck for a simple solution.
Is this for a bathroom? ...only asking because the outlet would be the same height as the switch; makes sense over a vanity, but you would want a gfci for it, of course.
Also, ... oh never mind. Too many things to cover with the information provided.
Take care.
Timster is offline
Old 07-27-2008, 09:01 AM   #3
mickeyco's Avatar
Trade: Squirrel Handler
More info needed. Romex-Conduit, number of wires present, color of wires present, was it a three-way switch, will the person working on it be wearing a hat? It can always be done, it's just a matter of how much work it will be.
mickeyco is offline
Old 07-27-2008, 10:14 AM   #4
MSSI's Avatar
Trade: Electrician
your electrician can do that for you no problem...
MSSI is offline
Old 07-29-2008, 04:40 AM   #5
huntington beach, ca.
hbelectric's Avatar
Trade: electrical
LOL
I bet i could make one of those hot wires a nuetral, i'm just saying.
hbelectric is offline
Old 07-29-2008, 10:46 AM   #6
mickeyco's Avatar
Originally Posted by hbelectric View Post
LOL
One of those wires going to the switch may very well be white and go back to a place where it could easily be hooked up to a neutral and the switch converted to an outlet.
mickeyco is offline
How many members of CT does it take to change a light bulb? Bill Off Topic (Non Trade) 19 01-05-2008 01:13 PM
Multiple fixtures on switch loop KenHaynes Electrical 2 12-05-2007 03:15 PM
light switch plate blank darren Electrical 12 06-14-2007 08:06 PM
smart light switch circuit toastermaker Electrical 7 12-07-2005 11:45 PM
