Trade: Flooring
Light Fixture With No Junction Box.
Electrical problem.
Need to install a light fixture on a concrete ceiling but there is no junction box in the ceiling. There is an electrical wall socket close to the ceiling and a switch that operates it. It is legal to use a regular light fixture, attach it to the concrete and use a regular electrical cable to connect the fixture to the wall socket? I would run the cable on the ceiling and hide it in a plastic painted cable guide. |
#2 | |
And I do electrical, too!
Re: Light Fixture With No Junction Box.Quote:
No, no, and no.
Site : the area or exact plot of ground on which anything is, has been, or is to be located. Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision. Cite : To mention in support, proof, or confirmation; refer to as an example. |
Trade: Flooring
I would use a grounded electrical cable and have the connections done inside the fixture mount. To me it was similar to connecting an garage door opener. Can you give some more explanation please?
Thanks for your help. |
Trade: Squirrel Handler
Some people climb mountains. I take out the trash. But we both do it for the same reason. |
#5 | |
Use wiremold or an old garden hose, I'd use the wiremold. .
A fixture designed to mount to a box is required to have a box. NEC 410.36.
You cannot substitue a cord for permanent wiring. 400.8(1). Doing what you are suggesting will likely result in your modifying the light to allow the cord in. This would violate the UL listing of the fixture. Will what you want to do work? Yes. Will what you want to do pass an inspection? No. Will what you want to do be safe? No. Will what you want to do end up as pictures on this forum under the heading "Look what this hack did!"? Maybe. Let's leave the hack wiring with a garden hose to Nancy Today.
Site : the area or exact plot of ground on which anything is, has been, or is to be located. Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision. Cite : To mention in support, proof, or confirmation; refer to as an example. Last edited by 480sparky; 03-19-2009 at 12:31 PM. |
Trade: Flooring
Any suggestions on how to have a light installed. How about using a junction box that has an outlet for a cord. The connect the light box to this junction box. Whould that pass code?
Wiremold. Or, call an electrician.
Electrical Contractor
Trade: Electrical Contractor
I smell DIY!
We are the people (our parents warned us about) (Jimmy Buffett) |
Handle It!
There is no need to do any sniffing out when a turd is fully visible.
home-work
Trade: carpentry
Concrete ceiling? Does this have anything to do with the fallout shelter thread?
"I may not be fast, but I am half fast." |
Fentoozler
I would :
a) Hire an electrician b) Supply a broom handle and install an array of these:
Service & Repairs
Trade: Electrician
I wouldn't hire an electrician, I'd just do it myself. Have you seen the rates electricians charge these days?
Maybe a swag light, those are back in fashion, aren't they?
#15 | |
Professional Instigator
#16 | |
#17 | |
Service & Repairs
Trade: Electrician
First I would make that duplex receptacle more accessible by upgrading to an extension box. From there, fittings, 10'-20' of 500 WM, some a back straps, anchor kit, 1/4" masonary bit, cordless hammer drill, 6' ladder, hacksaw, 4" round WM box, new duplex receptacle + cover (white), new plastic keyless fixture, and one shiny new 60 watt incandescent bulb. I would advise against using garden hoses and doorbell wire. |
#18 |
Fentoozler
Re: Light Fixture With No Junction Box.Kind of like a fart in church
#19 |
Trade: electrician Phoenix AZ
Simply run conduit from the existing switched recep to the ceiling, mount a jbox and install the fixture on the box.
It's not rocket science if you are any kind of tradesman. Look at how the othe conduit/wire is installed and duplicate it.
Just because it's within code doesn't make it safe. Just because it's against code doesn't make it unsafe. |
#20 |
Trade: web development
i am looking for bulk fixtures
| Trying to find retro light fixture... | remodbiz | Outdoor Lighting | 10 | 11-25-2008 09:36 PM |
| How many members of CT does it take to change a light bulb? | Bill | Off Topic (Non Trade) | 19 | 01-05-2008 01:13 PM |
| Changing a light fixture | ProWallGuy | Electrical | 38 | 08-22-2006 09:07 PM |
| Light fixture without junction box | ChuckEA | Electrical | 3 | 03-22-2006 09:54 PM |
