Light Fixture
Old 03-24-2007, 12:17 AM   #1
daveselectric
daveselectric's Avatar
Trade: Electrical
Light Fixture
Can anyone explain this? I had to trouble shoot a 175w 120v metal halide fixture. It worked fine on the work bench with a pig tail to test it but would not fire off when mounted to the building. The only difference in applications was the pig tail didn't have a ground. I isolated the ground at the fixture and now it works fine but I have no ground protection. Any suggestions?
daveselectric is offline
Old 03-24-2007, 01:02 AM   #2
faber307's Avatar
Trade: Contractor
Re: Light Fixture
any voltage measured on the fixture housing with that ground de-tached? BALLAST
faber307 is offline
Old 03-24-2007, 11:20 AM   #3
daveselectric
Trade: Electrical
Re: Light Fixture
None. It was a used fixture a customer wanted installed and it worked fine for a few days with a ground then nothing. Making it work ungrounded was purely accidental. I'm very reluctant to leave it that way and am stumped why the elimination of the ground made it work.
Old 03-24-2007, 02:57 PM   #4
Union Electrician
Sparky Joe's Avatar
Trade: Inside Wireman
Re: Light Fixture
Did you check voltages to ground? between hot and neutral, hot and ground and even neutral to ground?
Sparky Joe is offline
Area lighting for Pipe Guy mdshunk Electrical 5 01-26-2009 02:25 PM
How many forum members to change a lightbulb? Al Truistic Off Topic (Non Trade) 48 11-09-2008 01:46 AM
Light fixture heat? joasis General Discussion 5 08-26-2006 08:55 PM
Changing a light fixture ProWallGuy Electrical 38 08-22-2006 09:07 PM
Light fixture without junction box ChuckEA Electrical 3 03-22-2006 09:54 PM
