Trade: General contractor
LED Recess Lighiting
I am building a house and the customer may want to change the recess lighting to LED.
I need to round up samples to show the HO. Any opinion on them? Any brands I should avoid? Are they worth all the extra cost? Thanks in advance for any advice you can give me. Dave |
Electrosexual
Trade: Electrical Contractor
Re: LED Recess Lighiting
Very expensive. Totally not worth it.
Trade: Control Systems
I'm doing a job controlling some of these lights:
http://www.richelieu.com/produit/ind...1032641&o=7355 They look nice and cost a fortune. If you plan on dimming check with the manufacturer on what dimmers are compatible and whether you can use reverse phase dimmers on their power supplies etc. They are the way of the future. |
The last job I was on, the electrician used these guys
http://www.eco-story.com/oscommerce/...products_id=39 They are bright, they cost around $60, they don't get hot, they last 40,000-50,000 hours, and they burn about 5 watts.
#5 | |
Re: LED Recess LighitingQuote:
Initial cost is high but they are so cheap to operate and last much longer than conventional bulbs. I am sure the price will come down as they become more popular. Thanks for the link. |
#6 | |
Its all ball bearings
Trade: Tile
Recently I was bidding on a custom wine cellar so we looked at med base LED bulbs for the recessed cans. I was completely impressed by them. In a multi-bulb fixture, LED vs incandescent vs CFL, you could not tell the difference between LED & incandescent. As has been mentioned, 60W equivalent bulbs run around 5-7W. They do have 40,000+ hours life span. However, the one that I saw in a PAR30 form was $85. That's just insane to me. I suppose in a specialty application like the wine cellar, it's OK. But for everyday fixtures, I just think they're not ready for prime time. Once they drop in price, they'll overtake CFLs, no doubt.
Angus L+M+O+P=C ![]() "Promise only what you can deliver. Then deliver more than you promise" |
| The Following User Says Thank You to angus242 For This Useful Post: | crovello (11-15-2009) |
Trade: Electrician
I recently installed a bunch of the Cree LR6's. I was skeptical of the cost at first, but was totally impressed with the finished product. They look WAY better than a standard can and trim with an incandescent lamp, and the light distribution is much better as well. Unlike regular edison base screw in replacements, the light output on these are specifically engineered for perfect recess can placement. They are about $85.00 each and install into just a standard 6" recess can housing. I would put them in my house in a heartbeat, even at that price.
http://www.electri-safe.com/ |
Service & Repairs
Trade: Electrician
Had a customer who put these in the regular 4" IC cans I put in a month ago and they didn't look good, IMO. The dimmer buzzed and it just didn't look right. Light Emitting Diodes are in the future but they just didn't look good.
| The Following User Says Thank You to Magnettica For This Useful Post: | crovello (11-19-2009) |
| shallow ic recess slop cans! | Bkessler | Electrical | 2 | 10-15-2006 10:20 PM |
| it is safe to get power from a recess light | izote61 | Electrical | 4 | 10-12-2005 03:38 AM |
