Trade: electrical
Laser Tools
Does anybody know or use any other type of tool to measure out remodel recess cans besides the good old tape measure or string? Has anybody use any type of laser level for setting up cans in a room besides the laser that you put on the floor and shoots the laser straight up?
Re: Laser Tools
You reminded me of something a friend did on a job. He layed out the whole job on the floor. The lights, soffits bascially everything that was going in or being built out from the ceiling. He then sprayed the layout with clear varathane so it wouldn't get messed up when walked over. He said it really made that job easy.
Then he would use his laser to transfer his layout to the ceiling when needed. It also let him know very quickly if the other subs were installing their stuff in the correct location. Last edited by Tonkadad; 10-21-2005 at 02:25 PM. |
Re: Laser Tools
I been usingthe laser plumb bob made by Rack-a-teers for layout of recessed cans for the last couple few years. Just draw it out on the floor, then sit the laser over your marks and get yer red dot on the ceiling. I can't imagine any quicker way. This is just about the only way to get your cans placed accurately on a sloped ceiling. If there's a faster way, I'd sure like to know about it, but I don't believe there is at this point in time.
If you're laying out a ceiling box dead centered in a room, I just use my tape rule as a straight edge and take it corner to corner in the room and make overlapping lines in the center (an "X") rather than calculating the center of the room. That's faster than doing the math. Sometimes, when I'm boxing out a room, I'll write the room dimensions on the door header in case I need them later for any other layout. By the way, if you're not doing your ceiling work on stilts, you're losing a lot of time moving ladders around. Invest in a decent pair of stilts, and you'll speed way up. They're pretty easy to use, since they have a natural walking action. |
Re: Laser Tools
If you're doing remods, on tile you can lay out the ceiling using blue tape and a magic marker (to remind you of which tape intersection you are using). On hardwood flooring, I protect them with luan and you can mark directly on that.
The only thing better than a laser would be a higher powered laser that could cut the hole for you.
Trade: electrical
Re: Laser Tools
thanx for the input guys, md were could i find a descent pair of stilts
#6 | |
Re: Laser ToolsQuote:
Used, pawn shops. Double check that the springs are not broken and the straps and buckles are in good condition. These are available as replacement parts if you get a good enough deal on a ratty pair. I see now that your original post related to remodel cans. My response was geared mostly to new construction. For remodel cans, I always thought that if someone was to invent an X-ray vision tool, that would be great. How many times have you probed a spot, thought everything was okay, cut your circle, then exclaimed something like, "oh, crap". There is a tool called a "wall eye periscope" that is a lighted periscope that fits in a 2" x 2" hole that helps me out sometimes. It's easy to miss the joists, but sometimes there a pipe or something similar that eludes detection until you have the whole circle cut out. I suppose that's an age old problem that might not go away anytime soon, especially since you often need 5" to 7" of depth in that hole for the can. Last edited by mdshunk; 10-22-2005 at 08:32 PM. |
Re: Laser Tools
I don't know about your area but W/C here will not accept 'stilt claims', so I am told.
#8 | |
That reminds me of a time I thought I was going to get my but kicked by a drywaller because I let some conduit cutoff's lay in an area where they were working. I was getting moved out of that area little by little throughout that day, but I hadn't cleaned up all my scrap pipe and a few other boxes of crap yet. One particular rocker got a little excited about the pipe pieces, which caused me to take my sweet time cleaning it up.
Re: Laser Tools
md, was the rocker on stilts? I could understand him being ticked off with conduit drops on the ground.
My experience with stilts was 30 yrs. ago. I have no opinion, they took a little getting used to but became natural in short order. Heck, they weren't THAT tall.
#10 | ||
Trade: Master Electrican, Electrical Contractor
Re: Laser Tools
Mdshunk, does the rackateer's laser have self leveling?. If it doesn't you ought to try out the Fat Max self leveling laser level. It shoots straight up with a self leveling of up to 5 degrees off level on the floor. Saves big labor time using this for the cans, but be careful of laser light reflection when using recess cans, do not look at the beam or its reflection directly. As for stilts, we used to wire houses using them all the time. They work great if you use a ground man in conjunction with the guy up on the stilts working together. Also the extension pole for the whole hog drill while working on stilts makes ceiling drilling go even quicker. As I got older I learned there is no real reason to rush so much, every extra dime I make the wife just spends it all anyway so I retired my stilts and superspeed bust a__ years ago.
| Tools For Sales At Low Prices | man6_27260 | Contractor Swap | 1 | 06-30-2008 10:58 AM |
| Sheetrock Finishing Tools!!! | Mud Master | Drywall | 19 | 02-29-2008 06:58 AM |
| Opinions on the best tools for Pex | Dragonheart | Plumbing | 1 | 07-06-2007 04:16 PM |
| Relocating Tools: job to job | WNYcarpenter | Finish Carpentry | 36 | 04-04-2007 08:10 PM |
| Laser level for top plates on partition walls? | personalt | Framing | 3 | 11-12-2006 09:58 AM |
