tags, as close as possible to the opening tag. Creation Date: 12/20/2017 -->
L1 L2 On 110 Volt Circuit
Old 06-27-2010, 10:08 AM   #1
Steve
OCRS's Avatar
Neighbour in village has a roof mounted hood fan on chip wagon/trailer. It keeps thermal tripping. I ask my HVAC guy to take a look. He said the fan motor (new) was reversed wired. His understanding (and mine as well) is that on a 110 circuit, hot is L1, neutral L2. Sticker on motor says the same. White from motor to L1, then choosing the wire for the rpm you want from the motor to L2.
Thoughts?
OCRS is offline
Old 06-27-2010, 05:01 PM   #2
mrmike's Avatar
Trade: Electrical & Carpentry
Re: L1 L2 On 110 Volt Circuit
Thoughts?
First off- How do you reverse wire a 110 volt motor ? There are only 2 wires. Yes, Hot is L1 & but it is a black wire & not a white. The neutral is a white wire. If you reverse these it is a dead short
Also, There is no choosing for different RPM's with an L2 neutral wire.
I'M sorry, I am not trying to be smart, but this makes no sense at all, and that is why there are no answers here !!
mrmike is offline
The Following User Says Thank You to mrmike For This Useful Post:
rselectric1 (06-27-2010)
Old 06-27-2010, 05:30 PM   #3
Steve
OCRS's Avatar
Maybe I wasn't as clear as I thought. The motor has 4 wires coming from it. The label on the motor says which wires to connect depending on what speed you want from the motor. In all 3 examples it says white to L1 and then the wire for the speed you want to L2.
When we opened the box, it was black (1550 rpm) from motor to L1 and white from motor to L2 with blue and red capped, each giving a different rpm when connected to L2.
I know full well which supply wire is hot and neutral. What the HVAC guy was saying was that the electrician didn't follow the label on the motor and just wired it black to black, white to white.
OCRS is offline
Old 06-27-2010, 07:24 PM   #4
Steve
OCRS's Avatar
Here's the wiring instructions from the fan manufacturer
Name:  Greenheck motor.JPG
OCRS is offline
Old 06-28-2010, 06:31 AM   #5
mrmike's Avatar
I suggest you contact the Manufacturer on this one-as it makes no sense to me that it was wired black to L1 from the factory & that configuration is not on that plate. It leaves alot to be desired ! Sorry, I was no help..............
mrmike is offline
Old 06-28-2010, 07:53 AM   #6
Steve
OCRS's Avatar
There's no terminal board for this, just a connection box inside the housing. The fan internal wiring was done at the factory. It was the on-site electrician that connected it fan-black to L1, fan-white to L2.
Why the manufacturer chose to colour their wires in the manner they did is beyond me, but they did.
Based on the motor tag and fan docs, can we agree the electrician didn't follow wiring instructions? (hence my original "reverse wired" comment)
OCRS is offline
Old 06-28-2010, 08:52 AM   #7
Head Grunt
woodchuck2's Avatar
Rewards Points: 2,196
I would say the Electrician wired it wrong improperly per the manufacturers diagram, but how he wired it is normal for most applications. My question is why is the electrician wiring up the fan that would normally be the HVAC conractors job, or at least around here it is anyway? The diagram is calling for 3 different line feeds for change of speed so i am assuming there is a control box sending power to the fan? Did the fan come with a pigtail with all the properly color coded wires, if so then the electrician was wrong in not researching the proper wiring. If it did not come with a pigtail with the properly color coded wiring then i would say the electrician was doing what he felt was the proper way to wire it.
woodchuck2 is offline
Old 06-28-2010, 09:10 AM   #8
Steve
OCRS's Avatar
There is no external speed control, if I'm reading your post correctly. The documentation says to choose the rpm speed you need/want and connect the appropriate coloured wire to L2. There is a tag right on the interior housing beside the fan in plain view stating the wiring connection. I can understand an oversight in this situation regarding the black/white situation. What I don't get is why, when told and shown documention, he didn't connect it as specified. All wires were the colours stated on the tag.
As to my original question, would the wires being reversed (as wired by the electrician) cause thermal tripping?
OCRS is offline
Old 06-28-2010, 05:56 PM   #9
Head Grunt
woodchuck2's Avatar
I would say yes due to a possible direct short. What i fail to understand is how many wires are there at the fan motor? Is it just your typical black/white or are the other optional wires present? If there is going to be optional speed settings per color wire then there must be a speed controller somewhere, or are there more than the L1/L2 terminals to chose from? If the multiple wires were there at the fan motor and the diagram was in plain view then i would have to say he is at fault and being mis-wired could cause the tripping.
Old 06-28-2010, 06:22 PM   #10
Wood Butcher
bhock's Avatar
Trade: Remodels/Custom Cabinets/Granite Countertops
Woodchuck from what I am getting from OP is there are your standard 2 wires coming from power source, and 4 wires on the fan, alot of HVAC motors are like this. 1 wire on the fan is a common, the other 3 allow you to hard wire for the speed you wish, it is not something that can be controlled, you wire it one way get 1 speed etc. as long as it is wired with 1 wire to common and 1 to a speed select wire it should not make a difference on a 110 motor? right? unless there are capacitors involved? Not an electrician but was a licensed HVAC Tech for 5 years.
bhock is offline
Old 06-28-2010, 06:27 PM   #11
Steve
OCRS's Avatar
There's 4 wires coming from the fan motor. There is no connection board, only a 2x3 box. All 4 fan wires and the 2 supply wires (black/white)are in this box, the blue and red are individually capped. Of the 4 fan wires, tag says white to L1, then choose the fan rpm you want, connect the appropriate colour wire for that speed to L2 and cap the other 2. If you want raise, lower the rpm's later, change the wire from fan that's attached to L2. There's no external speed control as you are only connecting 1 of the remaining 3 wires to L2.
We checked, at the time, for an external thermostat, temperature probe but no go.
OCRS is offline
Old 06-28-2010, 06:29 PM   #12
Steve
OCRS's Avatar
My HVAC guy did say there was a capacitor. It didn't involve any of the wires previously mentioned and was mounted to side of fan.
OCRS is offline
Old 06-28-2010, 06:31 PM   #13
Wood Butcher
bhock's Avatar
On a side thought, it is very possible the motor just has a bad thermal protector from the factory! Has anyone thrown an ameter on the wire to check amperage draw? Checked actual operating temp with a infrared thermometer?
bhock is offline
Old 06-28-2010, 06:39 PM   #14
Steve
OCRS's Avatar
Bad thermal?, possibly. Our intention was to correct the wiring to supply and take it from there. After I was told that the electrician just returned the wires to his original configuration despite docs to the contrary, I told the neighbour that short of getting another electrician to investigate, our involvement was finished.
OCRS is offline
Old 06-29-2010, 07:29 AM   #15
Handle It!
MALCO.New.York's Avatar
Rewards Points: 2,000
Has anyone checked the line voltage or checked to see if the source is wired correctly?
Ultimate Wisdom---------
MALCO.New.York is offline
Old 06-29-2010, 08:05 AM   #16
Head Grunt
woodchuck2's Avatar
This is why i was asking how it was suppose to be wired and what controlled the speed. I figured either there was a speed controller somewhere to vary the voltage or their was a different series of brushes to control the speed. I think the OP should just reverse the wires like the diagram stated and run it. If it still trips then the problem is elsewhere.
The Following User Says Thank You to woodchuck2 For This Useful Post:
MALCO.New.York (06-29-2010)
Old 06-29-2010, 01:07 PM   #17
Steve
OCRS's Avatar
We metered the supply as soon as we saw the reversed wiring, and at least that part was wired correctly.
OCRS is offline
The Following User Says Thank You to OCRS For This Useful Post:
Old 06-29-2010, 01:33 PM   #18
Steve
OCRS's Avatar
That was our intention, to start at the beginning with correct wiring and go step by step to find the source of the tripping. But as soon as sparky just returned the connections to what he had before, we realized we're back to square one.
I got involved in all this because on the chip wagon's opening day, right out of the gate, the fan was tripping. I said call you're installer back. The neighbour says the electrician was called and he said they needed all new equipment. He just installed all this equipment and now has a quote in hand to replace it all. That's when I offered to bring in my HVAC guy for some diagnostics.
In the end, I said to the neighbour that I understood it was difficult for them but they had to take a stand one way or the other.
OCRS is offline
Old 06-29-2010, 02:32 PM   #19
Head Grunt
woodchuck2's Avatar
Well, at least your being a good neighbor about it so far. I would recommend putting that electrician out of the picture and hire another who hopefully may be more compatant in his profession.
Old 06-29-2010, 03:22 PM   #20
Steve
OCRS's Avatar
They have my # if they decide they don't want to get nailed in the keester.....again.
Thanks to everyone for your input.
Steve
OCRS is offline
18 volt Dewalt boman47k Tools & Equipment 0 06-04-2010 11:30 PM
Adding external controller and pump to water heater circuit? protechplumbing Electrical 5 05-12-2010 11:31 PM
New Basement Circuit dcapone Electrical Picture Post 16 09-30-2008 03:13 PM
Need help with 240 circuit Elast Electrical 6 10-19-2007 03:03 PM
12 volt lights Bkessler Electrical 1 03-08-2006 05:36 PM
