Knob And Tube
Old 11-23-2006, 01:14 PM   #1
Cabinetmaker
skymaster's Avatar
Trade: Cabinetmaker
Send a message via AIM to skymaster
Knob And Tube
At the risk of looking like a complete ***hole: Knob and Tube was banned or outlawed by Federal Law yes? Guess what I am trying to say is there should NOT be any of this live anywhere right?
Reason is my son-in-law is going to rent a house with option later on in Mentor Ohio, took a quick look at it last month and there are lots and lots of K&T in this house. It does appear that is was rewired, can see loads of new wire,panel etc however :} there are a couple of mysteries Yeah I know how is this new LOL LOL?. There are a pr of wall sconses over the fireplace, no switches apparent, only way to turn em off and on is to ready? turn bulbs. Thats the reason for question , also some switches do nothing, ( may just have been killed and left? ) Just need to be right when I open my mouth.
thanks
JackM
MD this should be right up ur alley
skymaster is offline
Old 11-23-2006, 06:57 PM   #2
Plan 9's Avatar
Trade: Electrical
Re: Knob And Tube
I don't think K&T was ever banned by law, I think it fell out of favor as wiring methods evolved and eventually the NEC did not endorse new K&T installations.
Those sconces at the fireplace, are you sure that's K&T? My instincts say black pipe, and I'm sure there's a buried switch box somewhere.
The house is probably what I call "A history of electrical wiring".
Plan 9 is offline
Old 11-23-2006, 07:49 PM   #3
Cabinetmaker
skymaster's Avatar
Trade: Cabinetmaker
Re: Knob And Tube
Plan 9; thanks for reply; I do not know what the wiring is as yet. I was looking for the correct answers from you electrical Pro's about likelyhood of it still being around and "live". Here in NJ it hasnt been seen in many many years all has been removed. My suspicions were aroused when I saw so much of it in this house, normally around here is is deactivated and removed.
Those sconses may prove to be veeeeeeerrrrrrrrrrry interesting Any ideas greatly appreciated.
JackM
Old 11-23-2006, 07:53 PM   #4
Cabinetmaker
skymaster's Avatar
Trade: Cabinetmaker
Re: Knob And Tube
Plan9 opps fergot; YES as to "a history of electrical wiring" If it is of interest to the folks when I go out in the spring I will try to take some photos for the "Ancient Wiring Museum":
JackM
Old 11-23-2006, 07:59 PM   #5
reveivl's Avatar
Trade: Renovations
Re: Knob And Tube
It's not that ancient, I run into it all the time, still live, still doing it's job. I am not a sparky but my electrician tells me that it is not a bad system, just it isn't grounded and the insulation on the wires is not up to modern standards.
reveivl is offline
Old 11-23-2006, 09:04 PM   #6
mdshunk's Avatar
Re: Knob And Tube
No, it was not outlawed. In fact, it is still in the code. Article 394, Concealed Knob and Tube Wiring. It is only permitted to be installed now under certain circumstances:
II. Installation
394.10 Uses Permitted.
Concealed knob-and-tube wiring
shall be permitted to be installed in the hollow spaces of
walls and ceilings or in unfinished attics and roof spaces as
provided in 394.23 only as follows:
(1) For extensions of existing installations
(2) Elsewhere by special permission
Knob and tube wiring was installed commonly well into the 50's, and the old-timers were still installing it into the 60's. The odd early 70's knob and tube installation can still be found here and there.
There is a form of knob and tube installation that is still legal today. It is called "Open Wiring on Insulators", and is basically knob and tube that is not concealed. You can install a brand new open knob and tube installation in industrial establishments and agricultural buildings if you want to, and it would be code legal. It is covered under article 396.
Knob and tube may have been jurisdictionally outlawed here and there, but there is no federal mandate. Wiring is a state's rights issue, and the federal government has never gotten involved in matters related to electrical wiring. Many insurance companies will insist that a homeowner have knob and tube removed in exchange for policy renewal or preferred rates.
mdshunk is offline
Old 11-23-2006, 11:43 PM   #7
Recovering Computer Guy
streetracer's Avatar
Trade: Home Improvement
Re: Knob And Tube
That's the part I would really be concerned about.
streetracer is offline
Old 11-24-2006, 12:24 PM   #8
GregS's Avatar
Trade: Low Voltage
Re: Knob And Tube
Another consideration:
Here in Ontario you will have an impossible time trying to resell a house with K&T wiring as insurance companies will not insure the house. Insurace is a requirement if you finance the house through a lender. You cannot even get insurance (at least a reasonable rate) if you have anything less than 100A service.
Obviously these requirements in your area may vary
GregS is offline
Old 11-24-2006, 06:52 PM   #9
bauler's Avatar
Trade: General and Electrical Contractor
Re: Knob And Tube
There have been fires caused by K&T when someone blows insulation on top of it. Part of the job of insulation is to dissipate heat. The old cloth/rubber stuff is fine in an open attic, but not smothered in insulation. Lower the price of the house by a complete rewiring job.
bauler is offline
Old 11-25-2006, 01:36 AM   #10
electrical contractor
brian11973's Avatar
Trade: electrical
Re: Knob And Tube
Got to ask, How many fires from insulation? Did a service change once. 30a 120v. Two K&T circuits. HO's of three months said both of the 20a fuses blew all the time. the 30a main never did. The insulation broke right off that 14 ga wire. Insulation had nothing to do with it. Crispy wire always has one , if not two sizes too big of a fuse on it.
The correct answer would be cheap, ignorate HO's that could not see that what was OK 50 years ago, is not enough today.( Ever find the "Lincoln" fuses?)
Also, just because you CAN screw that 30a fuse in doesn't mean you SHOULD. Some how the fuse gets bigger, the breaker, call an electrican. Those soldered taps can't handle that kind of load. This is why the AHJ's, insurance co's & everyone else wants to get rid of K&T. K&T could just about be all bare wire & it would work just fine.This is my opinion of K&T
brian11973 is offline
Old 11-25-2006, 09:25 PM   #11
Cabinetmaker
skymaster's Avatar
Trade: Cabinetmaker
Re: Knob And Tube
Thakns to all for your answers. Md thanks for the NEC tis printed out and saved . I truly hope that I do not find any of this live when I have to solve some of the mysteries of this house . Hmmm MD u seem closest to the crime scene case of beer and a burger :}:}:}
kiddin MD
JackM
