Jacuzzi 2 Pole 20,30
Old 06-05-2008, 05:30 PM   #1
listen twice talk once!
Bkessler's Avatar
Trade: electrician
I did a prep for a jacuzzi recently recently where I laid 40' of 1" pvc and pulled #6's and had the 50 amp gfi disco ready to go. But when they had the spa delivered it says it needs a 2 pole 20 and a 2 pole 30.What? How common is this? Tech support said I was screwed, I have never seen a 2 pole 20 or 30 gfi before. I know they exist but I still have never seen one. One buddy of mine said it should have came with a fancy disco, but it didn't. Does any one have any experience with this? Thanks bk..........go wings!
Bkessler is offline
Old 06-05-2008, 05:36 PM   #2
mdshunk's Avatar
Re: Jacuzzi 2 Pole 20,30
Yeah, I've run into quite a few of them like there. There's a special spa disco that you feed with your 50/60 amp and it has a 20 and 30 GFCI in it already. I forget who makes it, but it's on the shelf at my supply house. Something like spa specialties; don't quote me on that. I dont' have anything at hand right at the moment that I could tell you any better.
Myself, I don't really do any jacuzzi prewires unless I have dataplate information. Lacking that, they're getting an empty conduit from A to B for now.
mdshunk is offline
Old 06-05-2008, 05:41 PM   #3
Bkessler's Avatar
Trade: electrician
Well from this point forward I too no longer do spa pre wires unless I have a name plate as well.
Bkessler is offline
Old 06-05-2008, 05:42 PM   #4
wireless's Avatar
Trade: Electrician
I think Home Depot sells a Jacuzzi panel. Why can't you put a 60a GFI and then a sub panel by the jacuzzi?
wireless is offline
Old 06-05-2008, 05:42 PM   #5
Electrical Contractor
Speedy Petey's Avatar
Trade: Electrical
Typically those "20/30 breaker" spas come with the panel and breakers. I have yet to see one that didn't.
Speedy Petey is offline
Old 06-05-2008, 05:43 PM   #6
mdshunk's Avatar
Are you saying that the people get the disco when they buy the hot tub? That's a good idea, right there. That sure would save us electricians a lot of grief. The one hot tub store I wire for a lot just gives the customer an electrical cut sheet at the time of the sale.
mdshunk is offline
Old 06-05-2008, 05:55 PM   #7
Bkessler's Avatar
Trade: electrician
The one guy I talked to who had done one before said The disco came with the spa by the manufacturer. I would like to do some retro fitting if I could but I guess I can pull in some #12's and use the 6''s as the 30 amp. Is each of those has it's own neutral as well I guess?
Bkessler is offline
Old 06-05-2008, 09:03 PM   #8
Waco's Avatar
Trade: Electrical
I'm curious to know if you could use a 50 amp GFI to feed a subpanel with a double 20 and a double 30 in it.
Bet it wouldn't work.
Did the spa manufacturer specify GFIs for those two breakers?
Waco is offline
Old 06-05-2008, 09:04 PM   #9
Trade: Electrical
Yup, I can safely say every one of these I've done the panel has come with.
I forget, but I think one circuit is straight 240v, and one is 120/240v.
Old 06-10-2008, 02:23 PM   #10
Bkessler's Avatar
Trade: electrician
Do most of these disconnects come with both the breakers? and does any one know of a brand because I cannot find one in orange county?
Bkessler is offline
Old 06-10-2008, 03:45 PM   #11
Trade: Electrical
Do most of these disconnects come with both the breakers? The ones I have done did.
and does any one know of a brand because I cannot find one in orange county? The breakers and panels we all GE if I remember correctly. The brand of spa I couldn't say.
Added text to make post long enough.
Parking pole removal JamesNLA General Discussion 36 03-23-2008 07:43 PM
Pole Construction Cost EZCON Construction 0 08-24-2007 02:01 PM
Floor framing support for a jacuzzi FMKConstruction Construction 2 01-18-2007 12:11 PM
208 to 110 for outlet on pole Bkessler Electrical 3 11-16-2006 06:14 PM
Pole Barn Feeder sparkysteve Electrical 4 10-21-2006 08:57 PM
