I Used Romex In Pvc, Failed Inspection
Old 06-26-2009, 05:17 PM   #21
And I do electrical, too!
480sparky's Avatar
Re: I Used Romex In Pvc, Failed Inspection
Originally Posted by Stubbie View Post
Yeah I guess I did but that wasn't my point. If you talk to Southwire technical the conductors in NM-b are solid thhn/thwn-2 without the markings. So IMO there is no safety failure/issue to put them in conduit with the sheath removed. You just can't prove that to an inspector. Personally I just never do it other than protective sleeves and I never strip it.
An inspector only has to say, "Show me where they are Southwire conductors." You will be unable to prove it. You'll get red tagged every time if the inspector is on his game.
Site : the area or exact plot of ground on which anything is, has been, or is to be located.
Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision.
Cite : To mention in support, proof, or confirmation; refer to as an example.
480sparky is offline
Old 06-26-2009, 09:45 PM   #22
huntington beach, ca.
hbelectric's Avatar
Trade: electrical
Originally Posted by Magnettica View Post
Not me. Why would you accuse me of failing one of your jobs?
In your case here, PVC out to the island into a box (THHN/ THWN), and separate armored cables to each of your devices or appliances.
Dude I apoligize, i was only recalling that someone posted the code which stated you could run NM in PVC. Not that it was ok to run underground.
hbelectric is offline
Old 06-26-2009, 09:51 PM   #23
hbelectric's Avatar
Trade: electrical
Originally Posted by joe cool View Post
No! Stripped Romex is not THWN.
Yeah I was thinking about what I posted after I posted, going I bet that won't pass for this exact reason. I guess i'll go back to doing it the right way.
Old 06-26-2009, 10:54 PM   #24
Stubbie's Avatar
Trade: electrical
Yes, no argument there. I hope I didn't come across that it was ok to do. It is a violation as you previously posted.
Stubbie is offline
Old 06-28-2009, 02:19 PM   #25
220/221's Avatar
Trade: electrician Phoenix AZ
We have used romex in kitchen island PVC for EVER and just started to get called on it.
I use UF now on jobs where I think I might get called.
It's stupid but true. No NM in the slab. It's not too bad for the 20A circuits but when the cooktop or oven go in the island, we have to add JB's and change to thwn for the larger wire. More splices = more possible failure points.
Just because it's within code doesn't make it safe.
Just because it's against code doesn't make it unsafe.
220/221 is offline
Old 07-13-2009, 08:47 AM   #26
In the learning
electrichelper's Avatar
Trade: Student/Electrical
Send a message via AIM to electrichelper Send a message via Yahoo to electrichelper
You may have failed for several reasons. One, NM cable is not listed for a damp or wet location. In this case you need to run UF cable, which is Underground Feeder. Two, it depends what kind of PVC tubing you used. Did you use electrical grade which is gray in color, or did you use plumbing grade which is white? The only other things left are conduit fill and conduit size. What size conduit did you use and did it meet the requirements on the fill? Otherwise it may just be the inspector was being strick on you. Good luck to you.
electrichelper is offline
Old 07-17-2009, 10:40 PM   #27
dmanola7's Avatar
Trade: Electrician
Send a message via Yahoo to dmanola7
Is there a limit on the number of receptacles connected to the load side of a GFCI?
dmanola7 is offline
Old 07-17-2009, 10:44 PM   #28
480sparky's Avatar
Not per the NEC. There might be according to the specific manufacturer, although I haven't seen such a limit for years.
Old 07-26-2009, 04:01 AM   #29
EMF, PLC specialist
Softy's Avatar
Trade: Professional Pan Handler
Originally Posted by hbelectric View Post
Hey i'm confused a little, it's not direct burial, it's in pvc conduit, in a slab, in the kitchen.
I know the correct way, I had just read a thread about it being ok to run NM in PVC, I just missed the part about the underground, plus I see it done in every house we remodel.
I'll just put in a female pvc connector and romex connector and strip the wire.
I used 1 1/4 conduit, 3 -12s and 1 -14 nm.
I've never seen NM being use underground may be for low voltage purposes application. I always use THHN or THWN when going under. Good luck
Softy is offline
Old 07-26-2009, 04:14 AM   #30
EMF, PLC specialist
Softy's Avatar
What's UF - underground feeder? thanks
Softy is offline
Old 07-26-2009, 09:18 PM   #31
Baltimore Electrician
JohnJ0906's Avatar
Trade: Electrician
I have always wanted to see that in writing, but no one has ever produced it.
Also, it could be true for Southwire, but what about other brands?
John from Baltimore
"One Day at a Time"
All replies based on the 2008 NEC
Originally Posted by celtic
Deny Everything, Admit Nothing, Demand Proof
JohnJ0906 is offline
Old 07-27-2009, 02:54 AM   #32
Electric_Light's Avatar
Trade: student again
It is advisable to stick with the receptacle manufacturers recommendations. Some equipment leaks a few mA into the ground, such as a computer through filter capacitors. If you have too many outlets downstream and you plug in enough of them, the sum of leakage can be enough to cause a nuisance trip.
Electric_Light is offline
Old 07-29-2009, 04:40 PM   #33
In the learning
If you have read my post, I stated UF is underground feeder. What I didn't post was it MAY be listed for wet/damp locations and also some are UV rated against sunlight to a certain degree such as 90 degree C or 75, depending on the outer sheathing.
Old 07-29-2009, 05:19 PM   #34
Service & Repairs
Magnettica's Avatar
Trade: Electrician
You know an awful lot for being just a helper. I know "A" guys that don't know about temperature ratings or what UF stands for. You're gonna be a helluva electrician.
Magnettica is offline
What to expect from remodel inspection Hatter Electrical 57 07-26-2009 03:01 PM
Painting Romex? philcav7 Electrical 16 04-24-2009 10:33 PM
Failed another Hot tub inspection. K2 Electrical 20 01-02-2009 03:52 PM
cellar vrs basmenet egress...failed inspection RC LLC General Discussion 9 11-29-2008 10:23 AM
Win a M-Spector Digital Inspection Camera judeherr Off Topic (Non Trade) 1 08-11-2008 04:47 PM
