#1 | |
How Many Outlets Or Recepticles On A Circuit??
I know Ive read many times on these forums that there is no limit to receps on a resi circuit but i was in class the other night and the instructor, who was an inspector in 3 states, cited article 220.14 (i) and insisted that only 8 are allowed on a 15 amp and 12 on a 20.
Also i was wondering where the article is that limits the outlets on commercial . Thanks !!! |
Trade: Contractor
Re: How Many Outlets Or Recepticles On A Circuit??
220.14(J) Dwelling Occupancies. In one-family, two-family, and multifamily dwellings and in guest rooms or guest suites of hotels and motels, the outlets specified in (J)(1), (J)(2), and (J)(3) are included in the general lighting load calculations of 220.12. No additional load calculations shall be required for such outlets.
(1) All general-use receptacle outlets of 20-ampere rating or less, including receptacles connected to the circuits in 210.11(C)(3) (2) The receptacle outlets specified in 210.52(E) and (G) (3) The lighting outlets specified in 210.70(A) and (B) As outlined above the receptacles can be added to the 3 watts per square foot and there is no requirement to use the 180 volt ampere rule of 220.14(I) 220.14(I) Receptacle Outlets. Except as covered in 220.14(J) and (K), receptacle outlets shall be calculated at not less than 180 volt-amperes for each single or for each multiple receptacle on one yoke. A single piece of equipment consisting of a multiple receptacle comprised of four or more receptacles shall be calculated at not less than 90 volt-amperes per receptacle. This provision shall not be applicable to the receptacle outlets specified in 210.11(C)(1) and (C)(2). This rule is for commercial and industrial applications only. |
| The Following User Says Thank You to precisionbuild For This Useful Post: | K2 (01-26-2009) |
Fentoozler
The EI needs to keep reading (i) until directed to apply (j) [as precision detailed]
| The Following User Says Thank You to Celtic For This Useful Post: | K2 (01-26-2009) |
Trade: Electrician
Agreed this is not for residential applications..only commercial and industrial Gen Purpose outlets.
220.14(j) being the correct exception to the (I) article. "Also i was wondering where the article is that limits the outlets on commercial " Article 220.14(I) IS the article that limits unknown or Gen purpose outlets for commercial applications... "(I) Receptacle Outlets. Except as covered in 220.14(J) and (K), receptacle outlets shall be calculated at not less than 180 volt-amperes for each single or for each multiple receptacle on one yoke." |
| The Following User Says Thank You to TrblShooter For This Useful Post: | K2 (01-26-2009) |
| Kitchen - use 20A GFCI at start w/ 15A outlets??? | tmdelisle | Electrical | 25 | 07-28-2009 01:38 AM |
| New Basement Circuit | dcapone | Electrical Picture Post | 16 | 09-30-2008 04:13 PM |
| Need help with 240 circuit | Elast | Electrical | 6 | 10-19-2007 04:03 PM |
| Getting 15.6V on Dead Circuit - Why ???? | nasTTcar | Electrical | 19 | 07-24-2007 05:32 AM |
| how many outlets on a circuit | MO-AMPS | Electrical | 10 | 01-23-2007 02:08 AM |
