Hot Water Tank
Old 04-24-2007, 07:34 AM   #1
laybrick's Avatar
Trade: mason contractor
Send a message via AIM to laybrick Send a message via Yahoo to laybrick
Exclamation
Hot Water Tank
Can anyone help me ? I have a 220 hot water tank that has a black, red & a ground. The 220 line has black, white,& red wires & ground. Can I hook this tank up to it & if so, how? thanks
laybrick is offline
Old 04-24-2007, 07:43 AM   #2
Electrical Contractor
jbfan's Avatar
Trade: Electrical Contractor
Re: Hot Water Tank
Cap the white wire on both ends and wire the rest as color to color.
Maak sure the black and red are on a double pole breaker of the right amperge.
We are the people (our parents warned us about) (Jimmy Buffett)
jbfan is offline
Old 04-24-2007, 09:50 PM   #3
Service & Repairs
Magnettica's Avatar
Trade: Electrician
Re: Hot Water Tank
And if I could add to that.... make absolutely certain that a good ground bond is formed to the frame of the WH.
Magnettica is offline
Old 04-24-2007, 10:50 PM   #4
laybrick's Avatar
Re: Hot Water Tank
this will sound dumb,( hence the name laybrick, not lay electric) but , is it possible to tap into an existing 220 line ?
laybrick is offline
Old 04-25-2007, 02:20 AM   #5
Service & Repairs
Magnettica's Avatar
Trade: Electrician
Re: Hot Water Tank
For what reason would you want to tap into the circuit? I'm gonna have to say no, don't tap into it. Especially since you'll be capping the neutral and will not have 120 volts to ground for an receptacle or whatever. And... the 220 volt line you have now is probably just good enough to handle the load for the WH, and nothing else.
Old 04-25-2007, 06:42 AM   #6
jbwhite's Avatar
Trade: Electrician
Re: Hot Water Tank
I am not understanding part of this picture.
I had thought you were doing a direct replacement of an existing hot water tank. What 220 line are you wanting to use for your hot water?
jbwhite is offline
Old 04-25-2007, 09:03 PM   #7
laybrick's Avatar
Re: Hot Water Tank
from propane to electric. The wire goes to a seperate little breaker box upstairs. The box runs lights & plugs upstairs, wich won't hardly get used
laybrick is offline
Old 04-25-2007, 09:19 PM   #8
jbwhite's Avatar
Trade: Electrician
Re: Hot Water Tank
it needs to be on its own circuit
jbwhite is offline
Old 04-25-2007, 10:18 PM   #9
laybrick's Avatar
Re: Hot Water Tank
ok , thanks alot , that's what I'll do
laybrick is offline
Hot Water Tank Bird Plumbing 3 02-23-2007 09:47 PM
Hot Water Joewho Plumbing 13 11-17-2006 02:39 PM
Replace Hot water tank? RussellF Plumbing 6 09-19-2006 06:32 PM
Brick Footer and Water Proofing emtaboy Excavation & Site Work 24 07-24-2006 09:48 PM
Expansion tank on water heater Teetorbilt Plumbing 5 04-17-2006 01:53 PM
