Hot Tub Breaker
Old 07-30-2008, 10:32 PM   #1
aapex james's Avatar
Trade: general contractor
Hot Tub Breaker
I have an old hot tub, guessing 20 yrs old. Over the winter it developed a leak and I shut it off. Just fixed the leak and was looking at the wiring, for a test I thought I would push the test on the breaker to see if it worked. Nothing happens, tub keeps running. I had my electrician hook it up. I am sure we tested it before we started to use it 3 yrs ago. All looks correct. Took a wiring diagrahm off the net and everything looks good. Is it possible the breaker is bad? any ideas. Or should I have a different elec. come and check it out? Thanks James
aapex james is offline
Old 07-30-2008, 11:07 PM   #2
Thom
thom's Avatar
Re: Hot Tub Breaker
yes, it's possible the breaker itself is bad. If you have a GFCI breaker and pushing the button on the breaker doesn't trip it, you have a bad breaker.
thom is offline
Old 07-31-2008, 04:36 PM   #3
Service & Repairs
Magnettica's Avatar
Trade: Electrician
Re: Hot Tub Breaker
Perhaps the circuit breaker is wired incorrectly. The neutral from the load needs to be terminated directly to the breaker and the neutral attached to the circuit breaker gets terminated to the neutral buss.
Magnettica is offline
Old 08-11-2008, 06:47 AM   #4
JCH2O's Avatar
Trade: ELECTRICAL
Re: Hot Tub Breaker
Yes check the gfci breaker sound like it is possable its wired wrong ,magnetta is rt. I recamend getting a new one -hot tub
cheers
JCH2O is offline
Old 08-11-2008, 05:45 PM   #5
mdshunk's Avatar
Re: Hot Tub Breaker
Many of these breakers have a lifetime warranty. The Cutler-Hammer and Square D one's do, at least. Not something you want to plunk down another 50 or 80 bucks on if you don't have to.
mdshunk is offline
Old 09-01-2008, 09:21 AM   #6
TMG1's Avatar
Trade: Builder / General Contracting (including Plumbing & Electrical)
Re: Hot Tub Breaker
It sounds like a miswire or faulty breaker / gfci. wouldn't take a chance a use the tub again before its fixed. sounds like accident waiting to happen.,
TMG1 is offline
Old 09-01-2008, 09:37 AM   #7
Re: Hot Tub Breaker
I changed out the breaker. It work fine now. I need to add a timer now. The old tubs seem to run all the time. Thanks.
Old 09-10-2008, 01:08 AM   #8
bjgelect's Avatar
Trade: Licensed Master Electrician
Re: Hot Tub Breaker
GFCI breakers do not have lifetime warranties like their non-electronic kin. Although the C-H series breakers have a lifetime warranty, the CH250GF has only a 6 month, at least it did. Found out that the hard way when I warranteed it for life and it failed after 1 year.
bjgelect is offline
Old 09-10-2008, 05:13 PM   #9
Big Sky General
Big Sky General's Avatar
Trade: General Building, Electrical, Engineering.
Re: Hot Tub Breaker
When in doubt call an expert to CYA.
Big Sky General is offline
Old 09-10-2008, 11:24 PM   #10
Union Electrician
Sparky Joe's Avatar
Trade: Inside Wireman
Re: Hot Tub Breaker
I always assumed this to be the reason why GFCI receptacles say "test monthly".
The electronics are as cheap as possible (even cheaper in some cases), and to excuse liability (though there is no "test log" inside)
Sparky Joe is offline
Hot dryer breaker HandyAl Electrical 7 08-19-2008 05:34 PM
GFCI breaker appears to be bad 72chevy4x4 Electrical 14 06-03-2008 12:11 PM
circuit breaker panel spatial requirements Jefe Electrical 1 04-06-2008 09:16 AM
Breaker Panel? ccag235 Electrical 27 02-26-2008 09:14 AM
Breaker keeps popping DErnest Electrical 2 09-15-2006 06:30 PM
