Trade: painter
Hot / Ground Reverse Problem???
That's the indication my plug tester (not sure what you call it???) is giving me.
It's a strange problem, my christmas lights just stopped working. They were plugged into the House GFI outside. I found one other plug in my basement and a utility light in the furnace room that appear to be on the same circuit- they don't work either. The breaker was not tripped and the hot wire is still hot but things don't work when plugged in. So far I've opened up the box (outside receptacle) outside to inspect the wiring but it looked normal-nothing touching. What's going on here- Any suggestions before I call an electrician? Thanks, Charlie |
Trade: Renovations
Re: Hot / Ground Reverse Problem???
Not a sparky, but you pushed 'reset', right?
Trade: Contractor
Loose or open neutral either at the GFCI or before it at one of the connections is my bet.
Electrical Contractor
Trade: Electrical
That's exactly what it is. Bad neutral, the trick is finding it.
Trade: painter
Re: Hot / Ground Reverse Problem??? |
I was on a service call for an open neutral yesterday and it took me 2 hours ro find the offfending connection/junction box. But, are you sure the squirrels didn't chew one of the wires on your lights. That's what happens to my lights. Hot Neutral reversed should still work your lights.
Trade: painter
I've plugged in regular lamps and they don't work either. After opening 5 boxes and finding nothing unusual I realized there was still an unchecked box in the garage. This one has the GFCI outlet and there seems to be a problem here- the reset button does not reset, kind of looks like the test button stays pressed down.
I'm thinking I replace this outlet with a new GFCI and my problem is fixed. I'll buy one tomorrow and see but in the meantime if there are other suggestions please let me know. Thanks. |
#8 | |
Trade: Squirrel Handler
Re: Hot / Ground Reverse Problem???Quote:
Some people climb mountains. I take out the trash. But we both do it for the same reason. |
Trade: Electrical contractor/General contractor/ ICC certified electrical inspector
Re: Hot / Ground Reverse Problem???Voices in my head. .
Trade: Electrical & Carpentry
GFI's do not reset unless there is power on them , so I would check that first before replacing it I also believe you have a loose or disconnected neutral & I would start at the one outside. Sometimes when you have a loose connection it dis-connects when you plug something in, like your christmas tree lights.
Trade: painter
Turns out it was a bad GFI, I replaced the old one and everything works-thanks everybody.
#13 | |
| Tags |
gfi, hot ground reverse ![]() |
| Using RMC as a ground. | CNC | Electrical | 1 | 10-30-2008 06:27 PM |
| Bosch 12 dual mitre saw, transport lock wont hold? commen problem? | woodworkbykirk | Tools & Equipment | 10 | 10-28-2008 09:18 PM |
| eifs problem | Dorin Morgos | Masonry | 24 | 10-05-2008 04:10 PM |
| Concrete stain problem | Forry | Concrete & Paving | 6 | 09-02-2008 09:10 PM |
| Ground Up or Ground Down(no it is not another debate) | darren | Electrical | 18 | 04-12-2008 07:19 PM |
