Hot Dryer Breaker
Old 01-27-2006, 06:10 PM   #1
HandyAl's Avatar
Trade: Handyman
Hot Dryer Breaker
The breaker in our master bedroom tripped. When I went to reset it, I notice the breaker for the dryer was hot to the touch and it sits right below the master bedroom breaker. Is this a bad breaker or loose connection? I would like to have an idea of the problem before calling an electrican. I'm a handyman, but have limits on what I'll touch and that inlcudes the service panel.
HandyAl is offline
Old 01-27-2006, 07:09 PM   #2
Home Improvement Guy
ron schenker's Avatar
Trade: Renovations contractor
Re: Hot Dryer Breaker
Does the house have aluminum wiring?
ron schenker is offline
Old 01-28-2006, 08:59 AM   #3
HandyAl's Avatar
Trade: Handyman
No, I have all copper wiring. The service panel was upgraded about 5 years ago.
HandyAl is offline
Old 01-28-2006, 10:24 AM   #4
electrical contractor
bigjay's Avatar
Trade: electrical
It is probably one of these conditions:
1)Loose wire at the termination point on the breaker.
2)Loose connection where the breaker attaches to bussing.
3)Bad breaker.
I would have somebody look at this, if youre not comfortable doing it because this type of problem will only get worse and can be hazardous.
bigjay is offline
Old 08-19-2008, 12:45 PM   #5
pat c's Avatar
Trade: ELECTRICAL
loose wire off the breaker sometimes off the dryer seen it a few times
pat c is offline
Old 08-19-2008, 01:19 PM   #6
Jim M's Avatar
Trade: Electrical Contractor
Was the dryer in use when the bedroom breaker tripped?
Heat from the dryer breaker could have caused the bedroom breaker to trip.
Get this checked ASAP, turn the dryer breaker off.
Jim M is offline
Old 08-19-2008, 01:24 PM   #7
HandyAl
Trade: Handyman
A bit late for ASAP!
neolitic is offline
Old 08-19-2008, 05:34 PM   #8
220/221's Avatar
Trade: electrician Phoenix AZ
Turn off the main, remove and inspect the breakers and bus for signs of burning. Very common.
Just because it's within code doesn't make it safe.
Just because it's against code doesn't make it unsafe.
220/221 is offline
GFCI breaker appears to be bad 72chevy4x4 Electrical 14 06-03-2008 12:11 PM
gas dryer next to 3 gas water heaters fast pasquale Plumbing 9 05-26-2007 11:28 AM
Breaker keeps popping DErnest Electrical 2 09-15-2006 06:30 PM
gfci breaker Browny Electrical 6 05-29-2006 07:45 AM
Clothes Dryer wiring mjay Electrical 13 03-07-2006 06:21 PM
