Hole Sizes
Old 12-07-2007, 01:51 PM   #1
KentWhitten's Avatar
Hole Sizes
I have to template a granite backsplash with (obviously) electrical boxes for the kitchen. I have templated the actual box, but is there a specific size you guys like to see to get those little tabs to clear through? Like a minimum? I need single and duplex box sizes. I guess I'm assuming they are all the same size relatively? I hope?
Salmon Falls Cabinetry
KentWhitten is offline
Old 12-07-2007, 02:20 PM   #2
Fentoozler
Celtic's Avatar
Re: Hole Sizes
What kind of boxes?
Plastic or metal?
New work or old work?
Celtic is offline
Old 12-07-2007, 03:48 PM   #3
Service & Repairs
Magnettica's Avatar
Trade: Electrician
Re: Hole Sizes
If the electrical boxes are plastic then cut them out to that size.
If they're metal boxes be sure that the device screw holes are visible after the cut.
If I were you I would install 2" 6/32 screws into the box now so you know your cutouts will make the required clearance.
This sort of things ticks me off big time when done incorrectly.
Good luck!
Magnettica is offline
Old 12-07-2007, 05:36 PM   #4
Re: Hole Sizes
well, it's both really. It's a remodel and there's existing hard plastic ones, the dark brown kind, then they used some blue ones for the new wiring and they also have a metal box or two. I guess my hope that they'd be a std size was not to be. I templated to the corners of the box and am going to expand it slightly. I can't go too far or the dummy plates come out and make me look retarded.
Old 12-07-2007, 05:42 PM   #5
mdshunk's Avatar
Re: Hole Sizes
This is timely, since a countertop man visited a job I was on today to template for a laundry remodel Silestone backsplash. I've never seen the macnine they use in person until today. A sort of "robot arm" that they "beep" lots of points. Pretty cool.
For plastic wall boxes, with the screw ears internal to the box, beep all four corners of the box. For metal wall boxes, with the screw ears external to the box, beep all four corners of the box, and most imortantly... the screw ears. No way to put the screws in or out without the screw accessible. I wouldn't worry about templating big enough to get the device unburied. I generally just bust up the device and rip it out by any means, since new backsplashes mean new devices anyhow. If you template big enough to get the device's ears out easily, the new device's ears will have no support behind them when they're installed on the new backsplash and will be a sloppy install.
In short, just template for the full box height and width, and the screws when necessary, and don't template big enough for the device ears. If I've screwed you up on terminology, I can post pictures.
mdshunk is offline
Old 12-07-2007, 05:47 PM   #6
Re: Hole Sizes
OK, so these are the templated sizes. I have 4 different ones. Two doubles and two singles.
single - 2"x2-13/16"
single - 2"x3-7/16"
double - 3-3/4"x3-1/2"
double - 3-3/4"x3"
All width by height, all ballpark. The template is close but not perfect. i'm just trying to get 'er square and be nice to the electrician
Old 12-07-2007, 06:28 PM   #7
220/221's Avatar
Trade: electrician Phoenix AZ
Re: Hole Sizes
The mounting screws on a device (switch/receptical) are 3 3/16" apart.
Devices in a 2 gang box are 2 3/4" apart.
Single gang cover plates will cover MAX 3x4 1/2"
Two gang plates will cover MAX 4 1/2" square.
I don't know what the 2 13/16' hole would be for???
I would go wider than 2". The kitchen GCFI outlets are FAT.The plate will cover a 2 1/2" hole easily.
I don't know why the 2 gang boxes would be different. Mud ring on one of them?
As long as your installers have a roto zip....no problem.
220/221 is offline
Old 12-07-2007, 06:30 PM   #8
Fentoozler
Celtic's Avatar
Re: Hole Sizes
I don't think so.....
Celtic is offline
Old 12-07-2007, 06:31 PM   #9
mdshunk's Avatar
Re: Hole Sizes
Sounds like you're trying to do the right thing. Here's a few pictures I just took, which might contain some information valuable to you.
This first picture is of the box extension sleeves that the electrician will use to make the backsplash installation code-compliant, since the boxes are back in so deep. They fit inside the box, so you need a net clear opening for single gang of at least 1.910" wide x 2.920" tall. For double-gang, you need at least 3.720" wide x 2.920" tall.
This second picture is of the typical plastic wall box and an old-school metal wall box. Note that on the metal wall box, you need to allow for the "ears" on each end, so that they are not buried. The plastic wal box is 2.300" wide by 3.670" tall. The metal box is 1.950" wide by 3.600" tall (to allow for the ears).
This third picture is of taking a measurement of an actual receptacle. You'll note the measurement on the calipers is 3.600 just outboard of the screw heads. Go much bigger than this measurement, and the new receptacle's ears won't have anything to rest on. This is the most important measurement, in my opinion.
mdshunk is offline
Old 12-07-2007, 06:41 PM   #10
Re: Hole Sizes
damn shunk...thanks. that's perfect. I knew that they had to use those extensions for the granite. Those measurements are fantastic.
Old 12-07-2007, 06:46 PM   #11
mdshunk's Avatar
Re: Hole Sizes
Be advised that some electricians will install "adjustable depth boxes" for new work when they know of or suspect thicker backsplashes. These require a cutout to the full outside dimensions of the box so that the "jackscrew" mechanism can work to jack the box out flush. In my opinion, unless somebody points this type of box out to you, it is beyond the scope of any template man's job to have to identify this type of box in the field. I don't happen to have one on the truck, or I'd take a picture of one for you.
mdshunk is offline
Old 12-07-2007, 08:13 PM   #12
Fentoozler
Celtic's Avatar
Re: Hole Sizes
Originally Posted by mdshunk View Post
Be advised that some electricians will install "adjustable depth boxes" ....
Like this:
http://aifittings.com/whnew78.htm
Arlington's "One Box".
Celtic is offline
Old 12-07-2007, 08:16 PM   #13
mdshunk's Avatar
Re: Hole Sizes
Originally Posted by Celtic View Post
Like this:
Yeah, that's one type that I didn't give a thought to. Got lots of those on the truck. I was thinking about the blue Carlon one's that have the jackscrew thing-a-ma-jig on the side.
mdshunk is offline
Old 12-07-2007, 08:23 PM   #14
Fentoozler
Celtic's Avatar
Re: Hole Sizes
This puppy:
Carlon B121ADJ
Celtic is offline
Old 12-07-2007, 08:25 PM   #15
mdshunk's Avatar
Re: Hole Sizes
This puppy:
Carlon B121ADJ
Yeah, that's the one I had in my head. That was pretty much the only game in town before the Smart Box/In Box. They're pretty salty too. I think they're around 5 or 6 bucks, wholesale, as I remember. It would be pretty hard for the casual observer, such as a countertop guy, to tell the difference between that blue adjustable box and a regular blue nail on box from the finished appearance. The only real difference is that little screw head in the bump on the left edge.
mdshunk is offline
Old 12-07-2007, 08:30 PM   #16
220/221's Avatar
Re: Hole Sizes
You can tweak the cutouts in granite with a rotozip. You need the right bit of course.
I thought the box extensions didn't come into play since the granite isn't combustible??? Wrong again?
220/221 is offline
Old 12-07-2007, 08:41 PM   #17
mdshunk's Avatar
Re: Hole Sizes
In Zodiac you can, but real granite is a lost cause. Corian and Silestone is pretty much butter.
Hmmm... that's sorta ringing a bell. Let me check quick. You may well be right, but I still use them anyhow.
mdshunk is offline
Old 12-07-2007, 08:44 PM   #18
Service & Repairs
Magnettica's Avatar
Trade: Electrician
Re: Hole Sizes
Those adjustable boxes rule.
Old 12-07-2007, 08:47 PM   #19
mdshunk's Avatar
Re: Hole Sizes
Here we go. You get up to 1/4" if the wall material doesn't burn, and must be flush if it does.
314.20 In Wall or Ceiling. In walls or ceilings with a
surface of concrete, tile, gypsum, plaster, or other noncombustible
material, boxes shall be installed so that the front
edge of the box will not be set back of the finished surface
more than 6 mm (1⁄4 in.).
In walls and ceilings constructed of wood or other combustible
surface material, boxes shall be flush with the finished
surface or project therefrom.
I'll confess that I go over the 1/4" every once in a while. If the factory device screws reach, then I don't use a box sleeve. If I have to switch them out for longer screws, that's my que to use a box sleeve.
mdshunk is offline
Old 12-07-2007, 09:19 PM   #20
Al Smith
A W Smith's Avatar
Re: Hole Sizes
Ir sounds like hes describing the old Bakelite boxes from the late fifties/early sixties.
'brown hard plastic"
Al Smith
http://www.awsmith.com
A W Smith is offline
Repairing a hole in a plaster wall LukeCT Drywall 2 10-18-2007 04:27 PM
punch a hole in concrete /w #2 POOLMANinCT Masonry 7 06-23-2007 12:50 AM
Repair hole in hardboard siding cowtown Painting & Finish Work 6 05-23-2007 02:48 PM
Back panel hole england030 Carpentry 2 05-18-2007 10:05 PM
three hole receps on a ungrounded system? Steve Unkie Electrical 2 12-09-2006 11:44 AM
