High Leg Delta Transformer
Old 01-23-2009, 09:24 PM   #1
pudge565's Avatar
Trade: Electrical Occupations Student
Send a message via AIM to pudge565
Ok I have a question about a high leg delta transformer. I know that phases A and C to neutral you get 120 and that phase B to neutral you get 208. I also know that between any two phases you get 240. My question is why don't you get 328 volts from phase B to either phase A or C? I believe it has to do with the was the sine waves are off from each other but am not totally sure. Does any one have a good explaination? Or maybe a diagram of the sine waves?
pudge565 is offline
Old 01-23-2009, 11:00 PM   #2
My License Ain't 4 Sale..
InPhase277's Avatar
Trade: Electrical Contractor
Re: High Leg Delta Transformer
Draw the pic of a delta setup. You will see that between each phase is 240 V. With the high leg setup, all we've done is tap the center of the coil between A and C, giving us a neutral. We have not changed the relationship between each phase.
In other words, between any two phases, is one full transformer coil. Between B and N, there is a coil and a half. And the phase relation between the two sine waves is such that we get 208 V.
InPhase277 is offline
The Following User Says Thank You to InPhase277 For This Useful Post:
pudge565 (01-24-2009)
Old 01-24-2009, 02:08 AM   #3
Service & Repairs
Magnettica's Avatar
Trade: Electrician
What would you need 328 volts for?
Like 277 said, an open delta is just a regular single-phase set up with an additional transformer that's not center tapped. The 208 volts is a math equation. It's just a cheap way for the power company to deliver 3-phase power to it's customer but they are slowly but surely doing away with this set up.
Magnettica is offline
Old 01-24-2009, 12:55 PM   #4
pudge565's Avatar
I don't know what you would need 328 volts for but I was just curious as to why you don't get it.
pudge565 is offline
Tags
208 volts, delta, high leg, transformer
High Speed Cable & P.O.T. Separation? redzthredz Low Voltage 11 12-01-2009 05:09 PM
High Efficiency House Ideas Vrooman Green Building 43 02-12-2009 03:54 AM
Delta seat cups AJX4 Plumbing 2 08-28-2008 10:52 PM
Why did the transformer melt? Greg Di Outdoor Lighting 14 04-04-2008 12:03 PM
Houston Area Builders and Project Mgrs- Are you prepared for high tech homes HomeMedia Pros Business 10 02-19-2008 02:43 AM
