Trade: Masonary
HELP Me Find A 2-Gang 1-Decora Centered Device Receptacle Wallplate
Anyone know where I can find some of these? I found this one. http://www.twacomm.com/catalog/model...2D199066DFD7C3
However I need it in white. Thanks man I am having no luck. |
And I do electrical, too!
Re: HELP Me Find A 2-Gang 1-Decora Centered Device Receptacle Wallplate
Does it have to be centered?
Site : the area or exact plot of ground on which anything is, has been, or is to be located. Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision. Cite : To mention in support, proof, or confirmation; refer to as an example. |
Trade: Masonary
Yep, That is what makes it hard to find...
I've never seen a white centered. P&S makes one that is 2-gang with the device on one side. SP1426W.
Site : the area or exact plot of ground on which anything is, has been, or is to be located. Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision. Cite : To mention in support, proof, or confirmation; refer to as an example. Last edited by 480sparky; 08-25-2009 at 04:43 PM. Reason: Add image |
#5 | |
Electrical Contractor
Trade: Electrical
Re: HELP Me Find A 2-Gang 1-Decora Centered Device Receptacle WallplateQuote:
I see it is a valid part number, but what is the application? Maybe it is the size of a 2-gang. Like a tremendously oversized one gang plate?
#6 | |
Doofenshmirtz Evil Inc.
But then again why would you need it so wide?
in texas with framing and cornish people will do it for 3.00 a foot. What do yall think about that? Just laber |
Trade: Masonary
Also found another solution it is a n-1500-wh http://www.lutron.com/nova/?s=17000&t=17200 that would center a dimmer on the box, however expensive...
Fentoozler
Why do you need such an awkward plate?
Maybe there is an alternative to that particular plate for this application?
Trade: Masonary
Customer has a 2-gange box and just one switch. Does not want a blank or dummy switch. So searching for alternatives...
Trade: Electrical
That would not be a "2-gang" box then. That is a 4" sq with a mud ring.
Trade: Electrical
Sounds like a "Sorry. That's all there is." reply to me.
True.. I just cant think why he would need this..Unless someone did a crappy job of cutting out the box and it didn't get fixed....
If it is a normal two gang box,What are you going to screw the switch into if it is in the middle of the box?Not to mention what you will screw the plate into..
Trade: Electrical
The only way to get that type of cover in white is to custom order it, it is not cheap or quick but I have had to do it on more then one occassion.
#15 | |
Trade: Electrical
HOW was a device mounted in the middle of a two gang box???
#16 | |
Service & Repairs
Trade: Electrician
Do you smell bacon?
#18 | |
I think they're going to have to live with either a blank on one side, or use the plate I listed.
#19 | |
#20 |
Fentoozler
:: Left with no choice, hvnbnd knocked down the building to start from scratch ::
| How do you find workers ? | AnthonyTLLC | Business | 52 | 09-19-2008 07:46 PM |
| Did you have systems before your hired office help or did you find a miracle worker? | ruskent | Business | 13 | 09-08-2008 08:05 AM |
