Heat Shrinks
Old 09-15-2008, 11:28 PM   #1
pat c's Avatar
Trade: ELECTRICAL
Heat Shrinks
i saw this the other day, heat shrink over the "H" tap joint. I usualy tape it up and put plastic covers. is it worthed to heat shrink it ??
pat c is offline
Old 09-15-2008, 11:56 PM   #2
Teetorbilt's Avatar
Re: Heat Shrinks
We use dual wall heat-shrink on boats all of the time. Not sure of what the NEC allows, I'm sure that it's archaic.
Albert Einstein
Teetorbilt is offline
Old 09-16-2008, 05:18 PM   #3
mdshunk's Avatar
Re: Heat Shrinks
I just clip on the covers, but there's no reason why you can't heat shrink. You'd have to do 2 or 3 layers of heat shrink, or do one layer of that really thick stuff. The insulation has to be equivalent to the conductor's insulation, so that's a pretty good measure of how thick you need to build up.
mdshunk is offline
Old 09-16-2008, 08:36 PM   #4
pat c's Avatar
Trade: ELECTRICAL
Re: Heat Shrinks
anyone know of an heat-shrink u can wrap around the wire. Example... wire damaged inside an LB and u have 150 feet from both side. i tried cutting the Heat-shrink and wraping it around the wire but it " shrival's up"
pat c is offline
Old 09-16-2008, 08:39 PM   #5
Re: Heat Shrinks
shrivels
neolitic is offline
Old 09-16-2008, 08:47 PM   #6
pat c's Avatar
Trade: ELECTRICAL
Re: Heat Shrinks
shrivels
TY for clearing that up..........
pat c is offline
Old 09-16-2008, 11:54 PM   #7
Capra aegagrus
Tinstaafl's Avatar
Re: Heat Shrinks
Yes, there is a heat-shrink tape. Unfortunately, it's been several years since I had occasion to source/use it, and the cobwebs aren't letting the name through.
Anyone?
Tinstaafl is online now
Old 09-17-2008, 05:36 PM   #8
mdshunk's Avatar
Re: Heat Shrinks
For what you're asking for, I think I'd use "Linerless rubber splicing compound" or that paint-on electrical tape that 3M makes.
mdshunk is offline
Radiant Barrier Fact Sheet Ed the Roofer Roofing 0 02-09-2008 08:57 PM
Heat Exchanger Problem with Hayward Pool Heater jtc1062 Pool Construction & Enclosures 6 10-24-2007 10:33 PM
Heat Exchanger Problem with Hayward Pool Heater jtc1062 HVAC 2 10-22-2007 10:13 PM
heat pump help!?!!! maxkd HVAC 1 11-10-2006 08:57 PM
Heat Exchanger Inspection Methods MechAcc HVAC 3 04-14-2005 04:38 PM
