Trade: Electrical
Hdpe
Does anyone have experience with HDPE used as conduit? Is it UL approved?
Trade: Electrical Contractor
Re: Hdpe
Here is a website that might help you out.
http://www.arncocorp.com/Product.aspx?PAGE_ID=634 |
Technical Specialist
Trade: HDPE Pipelines
Re: Hdpe
I know of a lot of people that use HDPE for electrical conduit. There are a lot of benefits to it. Especially if there is a chance that this line will be in service for some time.
There are some resins that are UL approved. See the link in the above post. What sizes of pipe and how long are the runs? |
Trade: electrician Phoenix AZ
Re: Hdpe
When you adapt to PVC for fittings, 90's etc, you must use heat shrink tube on the connections. HDPE fits into the PVC fittings but glue won't hold it.
Just because it's within code doesn't make it safe. Just because it's against code doesn't make it unsafe. |
Service & Repairs
Trade: Electrician
Re: Hdpe
I've never seen or used it before.
Fentoozler
Re: Hdpe
Re: Hdpe
Because of the flexibility of HDPE you often don't need fittings. If you do, you may heat fuse HDPE fittings to the pipe. It is leak free and becomes one with the pipe. The fusion will be as strong or stronger than the pipe itself
I am not sure why you would want to use pvc fittings with HDPE pipe. Is there a requirement to do so? |
Re: Hdpe
You usually need to transition to PVC when you are entering the building to get a threaded end to attach to a box, or a glued end to enter a LB, etc.
We have used those threaded aluminum couplers, one end threads right over the HDPE and the other end you can thread a PVC male terminal adapter end into. |
| HDPE VS PVC Decking | wakespere | Decks & Fencing | 7 | 10-27-2008 06:55 PM |
| Info on Plastic Lumber/Composite Decking | orson | Green Building | 3 | 09-02-2008 08:28 PM |
| HDPE pipe mechanical couple | bsolar | Excavation & Site Work | 6 | 05-01-2008 04:30 PM |
