Home Builders/Contractors
Trade: Residential Home Builder/Contractor
Grounding Rods
Regarding 200 amp meter base combo install:
Looking for proper placement of copper grounding rods from meter base? If I recall the 1st rod should be 5' from the new meter and the second should be no less that 6' from the first. A little help would be greatly appreciated.... Thank you kindly. |
Electrical Contractor
Trade: Electrical
Re: Grounding Rods
There is no proximity to the first rod. Just that the two be at least 6' apart.
And I do electrical, too!
Re: Grounding Rods
Local & utility rules may also apply in your case. Check with your building department and power company.
Site : the area or exact plot of ground on which anything is, has been, or is to be located. Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision. Cite : To mention in support, proof, or confirmation; refer to as an example. |
Re: Grounding Rods
Thank you gentlemen.
BTW... nice website Sparky |
| Grounding rebar | carm | Masonry | 30 | 01-06-2009 11:21 PM |
| Size UFER | Chris Johnson | Electrical | 27 | 01-05-2009 07:51 AM |
| Need help with a shocking outside waterspout | Badoish | Electrical | 23 | 12-27-2008 04:18 PM |
| shocked when touching bath faucet | earl964 | Electrical | 28 | 09-16-2008 05:50 PM |
| What do you guys think? | krthomp33 | Electrical | 18 | 06-27-2006 08:59 AM |
