Remodeling GC
Grounding Flexible Gas Line?
Had a call tonight from my electrician about a builder complaining the other sparky did't ground the flexible yellow gas line, I thought that wasn't supposed to be grounded?
Kevin Basement Finishing Highlands Ranch Colorado Littleton Colorado, Basement Remodeling Kitchen Remodeling Denver |
Trade: Squirrel Handler
Re: Grounding Flexible Gas Line?
I thought those yellow flexi gas lines were coated with some type of pvc or plastic. I don't think you ground a gas line you bond it.
Some people climb mountains. I take out the trash. But we both do it for the same reason. |
#3 | |
Fentoozler
http://www.charmeck.org/Departments/...ST+Bonding.htm
http://www.iccsafe.org/cgi-bin/ultim...;f=11;t=001234 ...from another forum: http://forums.mikeholt.com/showthread.php?t=84103 ...a pdf: http://www.pddocs.com/csst/documents...l_bulletin.pdf You may want to contact the City and see how that particular local is handling this.
Trade: Electrical
There was a class action lawsuit over this issue, and as a result, the manufacturers are now requiring that the flex gas lines be bonded. Something about the flex line rupturing when struck by lightning, and causing fires. Bonding is accomplished by use of a solid fitting, and not directly on the flex portion of the line.
There may be some confusion over the terms grounding and bonding, since they are sometimes used interchangeably. But the proper term in this instance is Bonding. Edit: Looks like Celtic beat me to the punch on this one. |
#5 | |
Fentoozler
here is that class action:
http://www.pddocs.com/csst/ Quote:
Service & Repairs
Trade: Electrician
How bout banning this type of gas pipe to any building equipped with an electrical system. I believe it's a stupid idea to bond both gas and electrical systems. Whats next, bonding water supplies?
#7 | |
Fentoozler
Re: Grounding Flexible Gas Line?Quote:
250.104(B) says otherwise. Of course you are free to write a proposal to change that NEC article ![]() Close...bonding pool water.
Professional Remodeler
On a project recently, it involved a service change. The inspector red-tagged it because the hot water heater wasn't properly "grounded". My electrician didn't know what the inspector wanted, called him up, this is what the require now in that jurisdiction, bonding the hot, cold, and gas lines at the heater. Is this something new? Seems kind of dangerous to me, or am I just "old school" and it is better?
-Mike- Falcon Contracting Residential - Commercial
#9 | |
Service & Repairs
Trade: Electrician
So why are we bonding it twice? |
#10 | |
Service & Repairs
Trade: Electrician
#11 | |
When the electrician installed the new panel, he ran a #6 back to the water meter (and jumpered it) and to the two ground rods outside. I guess I am curious (electrician is to, the inspector didn't give a reason, just said it had to be there on the HWH.) I can see your reasoning for bonding between the hot and cold because if the dielectric couplings or removal (although almost surely temporary) of the HWH, but bonding everything to the gas line too? Sounds like an accident waiting to happen somewhere.
#12 | |
Baltimore Electrician
Trade: Electrician
The thing to remember, and the reason the CSST bonding got upgraded, is lightning induced voltage. Lightning does not need to directly strike a building to induce a voltage on metal systems. Without a path back to planet earth (grounding for real) this can remain as a capacitive charge, until a path is created for discharge. If that path is through a person....
John from Baltimore "One Day at a Time" All replies based on the 2008 NEC Quote:
#13 | |
Trade: Electrician
As far as the hot-cold-gas jumper at the water heater, thats where I did it, just because it was a common place for all three, and the first place an inspector would look for it.
Almost never see copper piping these days though.
Trade: Plumbing & Electrical
We are not allowed to use stranded here, only solid. But that bonding is correct. All 3 are to be bonded together. Another reason is if the home owner has a water softener or some filtration system, the plumbing remains grounded in the event of servicing or removal.
And tell your plumber to get those die-electrics out of their. Biggest rust generator you can buy. Use brass and by the looks of it, it will piss a leak from those nipples, before the bottom gets pin holes. I know they are allowed, but they are absolute garbage. As far as bonding the gas too, it is not dangerous at all. As John said "Without a path back to planet earth (grounding for real) this can remain as a capacitive charge, until a path is created for discharge." That is different than CSST. CSST issues are the actual line blowing open in the event of a direct lightning hit. Bonding it (to me) will do nothing, except get a few people and a bunch or lawyers rich.
"....And then we all switch places when I ring the bell" -Adrock
Fentoozler
We are not bondng it twice...we are creating an equal potential.
Service & Repairs
Trade: Electrician
Normally the equipment grounding conductor bonding the gas piping on a residential-type furnace is #12 AWG at best based on 250.104(B). what size EGC will be required for the flex?
Fentoozler
All the info is in the links provided.
#18 | |
Trade: Electrician
Actually, I think this suit arose from indirect strike damage. The charge would arc from the CSST to another system with a different potential, causing leaks. Let me see if I can find that file....
#19 | |
Trade: Electrician
I have a pdf file I would like to attach, but it is too large. Is there a host site I could use? (like photobucket for pictures)
How do you guys do it?
#20 | |
Trade: Electrician
http://www.snapdrive.net/files/50779...ngconcerns.pdf
Lets see if this works.... Hey it works! Check out the Overview (1.1) in this report. It says it's Indirect strikes this bonding is trying to mitigate. I don't see any way that CSST could take a direct strike, bonding or not.
| Shingles Nailed Above Nail Line.. Help!! | Unregistered | Roofing | 24 | 04-20-2011 09:14 PM |
| Need help with a shocking outside waterspout | Badoish | Electrical | 23 | 12-27-2008 04:18 PM |
| Running line to shed | 72chevy4x4 | Electrical | 24 | 03-31-2007 12:05 PM |
| Straight Horizontal Line | Speer007 | Carpentry | 17 | 12-15-2006 06:26 PM |
| Replacing residential sewer line | threequez | Plumbing | 1 | 10-17-2006 05:09 AM |
