Ground/Neutral Pigtail ???
Old 12-07-2008, 09:16 PM   #1
Master Electrician
Bubbles's Avatar
Trade: Electrical
Ok..we've all seen the dreaded neutral to ground screw pigtail...but...why the hell would anyone with a good ground in a metal box pigtail the neutral to the ground box screw?? It's also tripping (dead short) a 20 amp S/P breaker (MWC with no handle tie) even when everything is separated and in the clear ? It's also tripping the shared 20 amp breaker on same neutral even without the tie. Going back in late morning to figure out mystery.
Bubbles is offline
Old 12-07-2008, 09:21 PM   #2
Handle It!
MALCO.New.York's Avatar
Re: Ground/Neutral Pigtail ???
It IS what occurs at the Breaker Box!
Ultimate Wisdom---------
MALCO.New.York is online now
Old 12-07-2008, 09:25 PM   #3
Remodeler Extraordinare
A.W.Davis's Avatar
Well we expect a full detailed analysis when you figure out whats wrong
All the years of remodeling I have never seen ANY outlets in a metal box be pigtailed to the nuetral. Maybe somebody lost the nuetral due to a nail penetrating the wire behind a wall....I am not an electrician but that would be my first guess.
A.W. Davis Construction Co.
http://www.awdavisconstruction.com/
Your friendly remodeling contractor
A.W.Davis is offline
Old 12-07-2008, 09:27 PM   #4
mdshunk's Avatar
I'll bet you a nickel that someone replaced a receptacle served by both legs and didn't break out the tab, or they replaced a receptacle served by both legs with a GFCI and put both hots on the line side. I see that problem pretty often from flippers/rehabbers.
mdshunk is offline
Old 12-07-2008, 09:29 PM   #5
Custom Builder
Glasshousebltr's Avatar
same here
Bob
Glasshousebltr is offline
Old 12-07-2008, 09:31 PM   #6
mdshunk's Avatar
Originally Posted by Glasshousebltr View Post
same here
Hey Bob, long time no see. You out of jail now?
mdshunk is offline
Old 12-07-2008, 09:34 PM   #7
Custom Builder
Bob
Old 12-07-2008, 11:13 PM   #8
Service & Repairs
Magnettica's Avatar
Trade: Electrician
I don't think I fully understand what you're explaining here but I believe I can answer this:
To pass an inspection an inspector would use a plug-in type tester and check for proper wiring, equipment grounding conductor and all. By adding a bonding jumper (neutral to ground), doing this would accomplish what would appear to be a properly grounded receptacle.
You're losing me where this set up is creating a short circuit. Are you sure it's a short circuit and not a ground fault?
Good luck - you'll figure it out.
Magnettica is offline
Old 12-08-2008, 01:42 AM   #9
wireless's Avatar
Trade: Electrician
I had a call where some old cloth wiring burnt out years before I got there and someone "fixed" the problem by jumpering the neutral to ground. I was called because the hot finally burnt out.
wireless is offline
Old 12-08-2008, 04:20 AM   #10
reveivl's Avatar
Trade: Renovations
Welcome home, Bob.
reveivl is offline
Old 12-08-2008, 08:38 PM   #11
Master Electrician
Bubbles's Avatar
Trade: Electrical
Well, not much to report. We were kicked out by owner and maintainance guy. they said they would prefer to do any electrical needed by new tenant (my girlfriend). Anyhow, when she moves in then I'll sneak back in and figure out the problem. My father seemed to think it's a line to line short. Maybe it used to be a 220 volt fax machine on opp phases and the maint guy swapped it back and put them back on same phase or something. It still would kick out the shared hot as well even without a handle tie. Were going to look for some fishy things above acoustical as well. I'll report back when we check it out later. Thanks for tips in advance. Oh, btw the maintainance guy is also the painter, carpenter, drywaller, building supervisor etc...if you catch my drift...
Bubbles is offline
Old 12-08-2008, 08:51 PM   #12
Service & Repairs
Magnettica's Avatar
Trade: Electrician
That's why there's an electrical problem. If I were you I'd start isolating everything one splice at a time.
Old 12-09-2008, 09:19 PM   #13
220/221's Avatar
Trade: electrician Phoenix AZ
They had an open neutral and jumped to the ground to make it work.
Just because it's within code doesn't make it safe.
Just because it's against code doesn't make it unsafe.
220/221 is offline
pigtail length JamesNLA Electrical 8 01-03-2007 12:33 AM
