tags, as close as possible to the opening tag. Creation Date: 12/20/2017 -->
Gould Panel Cover... HELP!
Old 02-25-2011, 09:42 AM   #1
KOLA Mike
KolaWest's Avatar
Trade: Roofing, Exteriors, Investor Rehabs, Education
Exclamation
Hey guy n gals,
I'm relatively new here, but I figured I'd ask:
I'm in punch out mode of a townhouse that needs an electrical panel cover.
I threw out the old one, thinking I could find a replacement cover, no problem. Well, needless to say, I'm not an electrician. Tired Grainger and a few other odd supply guys who might have it, but I can't find one anywhere.
I know the whole UL-listing situation, and I'm starting to think I'll never find the 'right' cover (up to code and such, panel is probably from 1991 when the place was built). But, I wanted to see if you guys had a potential solution.
The panel cover is 15.5"x19". This is the measurement from the out side of the 'paint lines' that the old cover filled. It has 100 AMP service in it, and a bunch of Gould breakers. There is no manufacturer name on the panel box itself, just on the breakers.
The reason I tossed the old one is because it was all rusted and I figured I could find a replacement cover for $30-ish, and now I'm up a proverbial tree. I'm not in a position that I can replace the whole panel, nor was it part of the contract to do so. Obviously, I'm not going to walk away until I find something that works and is relatively safe.
Can anyone help me find a solution to this? Is there any flush mounted universal doors that aren't necessarily 'code', but will do the trick?
THANKS!!
KolaWest is offline
Old 02-25-2011, 09:56 AM   #2
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,883
Re: Gould Panel Cover... HELP!
You really want that kind of liability?
Chances are it's a Gould box. Siemens bought Gould years ago; you might find something compatible there.
Tinstaafl is online now
KolaWest (02-25-2011)
Old 02-25-2011, 10:00 AM   #3
KOLA Mike
KolaWest's Avatar
I'd hate to have the liability, but I'll probably have the owner sign a waiver of some sort. The contract sated I'd replace the cover, but that doesn't mean I'm responsible for the entire box replacement if one isn't available. I'm just trying to make it work somehow, and the owner knows what I'm trying to accomplish.
KolaWest is offline
Old 02-25-2011, 10:09 AM   #4
Capra aegagrus
Tinstaafl's Avatar
A waiver like that wouldn't hold up; it's essentially collusion to do something illegal.
I do understand your situation, but technically it is your responsibility to replace the whole panel if you can't find the proper cover for it. You're the one who brought it into non-compliance by discarding the old cover.
You can just go ahead and use whatever you can find, and chances are there will never be an issue. But it won't be legal.
greg24k (03-02-2011)
Old 02-25-2011, 10:17 AM   #5
KOLA Mike
KolaWest's Avatar
I appreciate the info and I'm not sure if that's the case in Colorado or not. But, it is helpful information.
KolaWest is offline
Old 02-26-2011, 04:27 PM   #6
hbiss's Avatar
Trade: Electrical
Rewards Points: 101
What the heck has Colorado got to do with it? Unless there is no code in your area (VERY UNLIKELY) you are on the hook. If you were an EC you would know better than to discard a cover regardless of how bad it is. Rust could have been removed and the cover repainted. It is VERY unlikely that you will ever find an original cover unless the panel is very recent and even there you will probably have to purchase a whole new panel just for the cover. There is no such thing as a universal replacement cover, that would not be legal even if they could be made which is impossible given the many thousands of different panels out there.
If the original cover is so bad that it cannot be used or it is missing you must replace the entire panel. Suck it up, you were stupid enough to throw out the old one. Now pay an EC to make it right.
-Hal
hbiss is offline
Old 02-26-2011, 08:08 PM   #7
Dierte's Avatar
Trade: Commercial Electrician
Rewards Points: 83
You can try looking on the net. There are some supply places that have some absurd stuff in stock. But from here, it looks like your sh*t creek w/o a paddle. Next time ask a real electrician before ASSuming you can find an outdated panel cover.
Dierte is offline
Old 03-01-2011, 04:46 PM   #8
KOLA Mike
KolaWest's Avatar
-Hal
You're correct, sir and that's exactly what I'm going to be doing. I got it worked out and thanks for the advice. Maybe try working on the bedside manner a bit, eh? Maybe I'll go find your posts and call you stupid too. That's real nice, chief. I was looking for answers, not criticism. I already realized I made a mistake, hence the thread.
KolaWest is offline
Old 03-01-2011, 04:48 PM   #9
KOLA Mike
KolaWest's Avatar
Already called a dozen places and the only thing that makes sense is replacing the box. I consider myself a pretty resourceful guy and just couldn't find a solution, so I'm trying to do the right thing. This will be the last time I ASSume anything, believe me.
KolaWest is offline
Old 03-01-2011, 09:28 PM   #10
Head Grunt
woodchuck2's Avatar
Rewards Points: 2,196
You can try here, they may have a panel cover or at least a replacement panel if that is the make/model yo want to stay with : http://www.relectric.com/Panelboards
woodchuck2 is offline
Old 03-02-2011, 02:29 PM   #11
avguy's Avatar
Trade: A/V, Renovation
Rewards Points: 250
Check around for electrical surplus warehouses.
The one I go to a few times a year has almost anything you can imagine from Bakelite switches to substation components.
Philip LaDue
Empire State Light and Sound
646-397-5028
avguy is offline
Old 03-02-2011, 04:04 PM   #12
JBrzoz00's Avatar
Trade: Electrician
Rewards Points: 129
Powerpoint Used electrical equipment
(248) 442-0810 20741 Inkster Rd, Farmington Hills, MI 48336
JBrzoz00 is offline
Old 03-02-2011, 11:24 PM   #13
jack of all trades
one man show's Avatar
Trade: general
Rewards Points: 75
go to home depot buy a brand new 100 amp panel comes with 20 breakers for abou $60.00
liability just aint worth it
this one is a service panel but they are cheap
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
one man show is offline
Has anyone read code book cover to cover? mehtwo General Discussion 31 12-22-2010 10:23 PM
New service panel from ex.panel galixy250 Electrical 1 12-20-2010 09:29 PM
wainscoting on stairs- panel spacing keith mathewson Finish Carpentry 0 06-23-2010 09:07 PM
electrical panel voltage issue DMC Electrical 7 05-01-2010 06:21 AM
panel in guest house veer Electrical 15 08-10-2008 04:42 PM
