Philadelphia electrician
Trade: Electrical contractor
GFI Memory Test
Do any of you esteemed ladies and gentlemen remember the timing of GFI receptacle changes? [so I can be lazy...]
We were putting them in in the early 70's and covering the outside recp from the bath GFI off a lighting circuit. I have someone with a house built in 1999 that has a GFI in the garage which knocks out their bathroom recps and exterior recp. Seems to me that this isn't kosher [and wasn't then]. Anyone remember change dates? or know where I can find them? thanks
Philadelphia electrician |
Re: GFI Memory Test
1971 Receptacles within 15 feet of pool walls
1971 All equipment used with storable swimming pools 1973 All outdoor receptacles 1974 Construction Sites 1975 Bathrooms, 120-volt pool lights, and fountain equipment 1978 Garages, spas, and hydro-massage tubs 1978 Outdoor receptacles above 6feet 6inches grade access exempted 1984 Replacement of non-grounding receptacles with no grounding conductor allowed 1984 Pool cover motors 1984 Distance of GFCI protection extended to 20 feet from pool walls 1987 Unfinished basements 1987 Kitchen countertop receptacles within 6 feet of sink 1987 Boathouses 1990 Crawlspaces (with exception for sump pumps or other dedicated equip.) 1993 Wet bar countertops within 6 feet of sink 1993 Any receptacle replaced in an area presently requiring GFCI 1996 All kitchen counters – not just those within 6 feet of sink 1996 All exterior receptacles except dedicated de-icing tape receptacle 1996 Unfinished accessory buildings at or below grade 1999 Exemption for dedicated equipment in crawlspace removed Under the '99, that bathroom circuit was only allowed to serve other stuff if it was another bathroom receptacle. |
Re: GFI Memory Test
amazing MD
did you pull that out of your head, or was it written down someplace you could find it? [actually, I expected it would be you who would know...] If the house was built using '96 [approval lead times and all], the bath outlets were still supposed to be separate, though, right? [I can't find my 96 and 99] ... and, thanks
Philadelphia electrician Last edited by RobertWilber; 09-29-2007 at 12:26 PM. Reason: manners |
Master Electrician
Trade: Electrical
Re: GFI Memory Test
Couldnt tell you how many times I've reset GFI's and turned 1/2 the house back on. It's an easy $100. Arc Faults are even better with all Ceiling Fans and old clocks and such people are buying. Keep Adding all you want NEC!!!
Thom
Re: GFI Memory Test
Years ago on a remodel I tripped an exterior receptacle downline of a gfi recept. Found the recept an hour later, behind the refrigerator.
Re: GFI Memory Test
I have several such lists of the history of certain requirements. I keep updating them with little tidbits as I learn them or come across them. The lists are just a copy and paste away. Also, you might want to treat yourself to the book "Electrical Inspection of Existing Dwellings", by Douglas Hansen, et al. It's a fantastic book with lots of similar historical information.
#7 | |
Baltimore Electrician
Trade: Electrician
Re: GFI Memory Test
Looks like the requirement for the 20 amp circuit for bath receptacles started in '99. (210-11(c)93)) Couldn't find it in the '96, and that seems to match my memory as well.
John from Baltimore "One Day at a Time" All replies based on the 2008 NEC Quote:
#8 | |
Re: GFI Memory TestQuote:
WAIT... I'm still reading... The 1996 was the first edition for the dedicated circuit for the bath receptacle, and it wasn't even allowed to do the lights either. The exception was added in the '99 that permitted the bath receptacle circuit to do the lights in the bath only as long as it didn't leave the bathroom. Looks like that wasn't legal under the '96 either. Last edited by mdshunk; 09-29-2007 at 07:36 PM. |
#9 | |
Trade: Electrician
Re: GFI Memory Test
Where did you find it in the '96? I couldn't find it?
#10 | |
Trade: Electrician
Re: GFI Memory Test
Never mind, they hid it in plain sight - again! 210-52 (d)
Electro-Mech. Contr.
Trade: Mechanical Contractor
Re: GFI Memory Test
Usually the best place.
"Injustice anywhere is a threat to justice everywhere" mlk 100% Union and Proud of It |
Re: GFI Memory Test
It's hard enough keeping the code straight, but every now and again you need to reference older versions or try to remember how it was back whenever to see if something was even proper for the time it was done. Most of the time I just tell people that this doesn't really meet code nowadays, and give them the opportunity to have me "fix" it.
listen twice talk once!
Trade: electrician
Re: GFI Memory Test
I remember in 1997 the first house where I had to change the bath plug from the garage/outdoor/basement plug circuit to the dedicated 20 to pass the inspection,... It was in downtown pontiac michigan in the winter. I went back after we were redtagged to fix it in the evening after dark in the hood.
| Taking Michigan Builders Test | cjc21021 | Contractor Licensing | 14 | 01-20-2010 01:31 PM |
| illinois residential roofing test | the roofman | Roofing | 17 | 05-27-2009 08:34 AM |
| Master's test Ky. | Moonray | Plumbing | 6 | 04-13-2008 08:42 PM |
| Electrical Test Safety | Dansbell | Electrical | 15 | 09-22-2007 11:48 PM |
| apprentice test | drywaller56 | Plumbing | 3 | 02-22-2006 08:02 PM |
