Trade: carpenter/ handyman
GFCI Question
Out of the blue today my GFCI on the load side to a light fixture lost it's neutral. When I tested the GFCI not only did I find out that I did not have a neutral anymore, but the ground was now hot @120V. I changed the GFCI & problem fixed.
Is this a common occurrence with the builder's special outlets? Steve |
#2 | |
And I do electrical, too!
Re: GFCI QuestionQuote:
Where, exactly, did you loose a neutral? At the light, or on the back side of the GFI recep at the load neutral? If you had a loose connection, repairing it should have solved all the problems.
Site : the area or exact plot of ground on which anything is, has been, or is to be located. Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision. Cite : To mention in support, proof, or confirmation; refer to as an example. |
Re: GFCI Question
480sparky,
It started when an outside outlet suddenly stopped working. My circuit tester showed that the neutral was open. The connection wasn't bad, but I changed the outlet anyway. I traced the outlet to the load side of a GFCI in the garage. My circuit tester showed an open neutral on the load side & a "hot" ground. As I said before, a new GFCI took care of the problem but I can't understand why it happened? Steve |
Steve
Re: GFCI Question
Internal failure?
Home Depot aisle walker
Trade: home remodeling
Re: GFCI Question
Take apart the old "bad" gfci and see if you can see an obvious problem, mechanics 101
Re: GFCI Question
When you installed the new GFI, you made the connection tight again.
Re: GFCI Question
Not a bad connection on neutral & even if that were the case, that wouldn't cause the ground to go hot? I wish that I would have taken the old GFCI apart before the trash man took it.
Steve |
| Question from lawyer trying to help contractor | scp | Business | 52 | 02-25-2011 01:23 AM |
| Question for GC re: rough/final cleans | britanie | General Discussion | 6 | 06-07-2009 07:42 PM |
| GFCI question | ChuckEA | Electrical | 12 | 11-04-2005 08:45 PM |
