GFCI Question
Old 08-04-2007, 10:17 PM   #1
RobertCDF's Avatar
Trade: Custom deck builder
GFCI Question
Hey guys when I am working on someones house I am usually plugged in outside and that is usually tied to a gfci in the bathroom or kitchen or garage. Problem is sometimes I trip these and dont have access to the house. So my question is if I switched out the outside outlet for a gfci outlet would that one trip before the one inside?
I also trip breakers on occasian and would love if I could set up a box that MY breakers would trip first. I know I can do that with a 15 amp if I am plugged into a 20 amp... But who puts 20 amps outside anyway? (besides smart people) Any suggestions to make this work would be great as well.
RobertCDF is online now
Old 08-04-2007, 10:25 PM   #2
mdshunk's Avatar
Re: GFCI Question
No sure-fire cure for either event.
Just make sure you have interior access, is my only suggestion.
Either that, or run off your generator.
mdshunk is offline
Old 08-04-2007, 10:33 PM   #3
Fentoozler
Celtic's Avatar
Re: GFCI Question
Portable GFI cord-set perhaps?
For the tripping issue...good luck ...genny or SOL.
Celtic is offline
Old 08-04-2007, 10:36 PM   #4
When It Rains, It Pours..
highlife77's Avatar
Trade: Remodeling(Everything)
Re: GFCI Question
I changed out a couple of my ext. cords with gfi to avoid this prob...so far so good.....good luck.
"When It Rains, It Pours"....
highlife77 is offline
Old 08-04-2007, 10:38 PM   #5
mdshunk's Avatar
Re: GFCI Question
If your portable GFCI trips before the one inside the house, you're just getting lucky. It's a crap shoot which one will trip first. There's nothing peculiar about the technology that would necessarily cause the one closest to the load to trip first.
mdshunk is offline
Old 08-04-2007, 11:22 PM   #6
Service & Repairs
Magnettica's Avatar
Trade: Electrician
Re: GFCI Question
Right, the GFCI trips when it detects a difference of current from the hot through the neutral. If you've got 2 amps going in and something less going out well then the GFCI senses this and trips out. This could happen anywhere in the circuit where there are multiple GFCI devices.
Magnettica is offline
Old 08-05-2007, 09:31 AM   #7
RobertCDF's Avatar
Re: GFCI Question
Bummer... How about these boxes I have heard of that you can alligator clip onto the AC or hot tub boxes.... Anyone want to give me some ideas about building one of these?
I do have the generator for backups.... But that can really get annoying after a bit.
I use the no access needed as a selling point. People are usually uneasy about contractors so I tell them that I dont want access.
Old 08-05-2007, 09:57 AM   #8
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Re: GFCI Question
Have you though about a set up that would let you plug into the dryer outlet?
Mike Finley is offline
Old 08-05-2007, 11:52 AM   #9
reveivl's Avatar
Trade: Renovations
Re: GFCI Question
It requires access, at least once, but I have a small breaker panel that plugs into the dryer/stove outlet, and gives me one thirty amp (for the comp.), two twentys and a gfci.
reveivl is offline
Old 08-05-2007, 12:32 PM   #10
Service & Repairs
Magnettica's Avatar
Trade: Electrician
Re: GFCI Question
I wouldn't tap off the A/C disconnect simply because I am an electrician and I know that it's not safe to do what you have suggested. Someone could get seriously injured if they don't know what they're doing. Besides, not everyone has central air conditioning so then what do you do? I understand that generators are loud, require maintenance, and don't forget to bring fuel either, but in all honesty that seems to me to be the best way to go.
Old 08-05-2007, 01:29 PM   #11
RobertCDF's Avatar
Re: GFCI Question
What do you do when they want to use the dryer?
You know most of these problems could be solved if you dang electrians would just put a 20 amp outlet outside!
Or if there was 2 differant outlets then I could plug the trailer with the compressor to 1 and then work off the other and not have to wory about the compressor trying to kick on while I am using the table saw or the worm drive.
Old 08-05-2007, 03:48 PM   #12
Thom
thom's Avatar
Re: GFCI Question
Actually, on all my houses I go one better. All convenience receptacles are 20A AND the panel is an exterior combination panel. I got tired of going back and not being able to get to the panel, piles of crap in front of it, shelves in front of it, etc. Three years ago when Square D recalled all the previous years AFCI breakers I was able to change them out without scheduling with the owner. Just went to each site, swapped the breakers, and moved on.
thom is offline
Old 08-05-2007, 03:57 PM   #13
reveivl's Avatar
Trade: Renovations
Re: GFCI Question
They get to use the dryer after I'm gone and before I get there, never had a problem yet, but I don't advertise that I don't need access to the house, so this might not work for you.
reveivl is offline
Old 08-05-2007, 05:05 PM   #14
mickeyco's Avatar
Trade: Squirrel Handler
Re: GFCI Question
I've used outdoor lighting that was controlled by motion and/or photo voltaic (power on all the time) to hard wire to for temporarily use (length of job) with my own breaker. You can get breakers in just about any size 13, 14, 17, 18 amp, whatever you need to prevent the breaker inside from tripping first. If the problem is happening mostly when your compressor comes on you might consider putting together something that won't allow the compressor to come on when you're using the other tools.
mickeyco is offline
Old 08-05-2007, 11:53 PM   #15
canuck88's Avatar
Trade: Electrical
Re: GFCI Question
+1 - I do the same.
canuck88 is offline
Old 08-17-2007, 07:29 PM   #16
Philadelphia electrician
RobertWilber's Avatar
Trade: Electrical contractor
Re: GFCI Question
A realistic alternative is to get a small 120/120 transformer.
Set it up for the primary to plug into the GFI receptacle. Then you can bite the secondary and the GFI won't trip.
Just set up a GFI receptacle off the secondary so you are protected while working. You can even add a breaker on the secondary so you don't trip the inside unit with an overload.
I can hardly wait for practical fuel cells.
RobertWilber is offline
low voltage question wraiths Electrical 12 01-02-2007 10:45 PM
Double GFCI Problem Or No? CGofMP Electrical 2 01-26-2006 09:43 PM
GFCI question ChuckEA Electrical 12 11-04-2005 08:45 PM
