#21 | |
EMF, PLC specialist
Trade: Professional Pan Handler
Re: Gfci ProtectionQuote:
#22 |
EMF, PLC specialist
Re: Gfci Protection
I thought it measure Voltage between ground, ie: 0-115, hence "Ground Fault" CI and if it trip too many time you'll have to replace the unit. There're some place that required the unit be replace once the unit trip.
#23 | |
And I do electrical, too!
If the amperage of both the grounded (neutral) and ungrounded ('hot') are the same, all is well as far as a GFCI is concerned. If there's a difference of more than 5ma, then it turns the circuit off. Voltage doesn't enter into it.
Site : the area or exact plot of ground on which anything is, has been, or is to be located. Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision. Cite : To mention in support, proof, or confirmation; refer to as an example. |
#24 | |||
Baltimore Electrician
Trade: Electrician
Properly operating appliances and equipment don't trip GFCIs. If they are leaking current to ground, higher than 5 ma, than the GFCI should trip - it's doing the job it was designed for.
John from Baltimore "One Day at a Time" All replies based on the 2008 NEC Quote:
#25 | |
Trade: apprentice electrician
#26 | |
#27 |
Re: Gfci Protection
I get that. He wasn't very detailed in describing the bar. (does it have a permanent facility for food prep and cooking?) but in a kitchen only receps serving the counter have to be GFCI but from the sound of his question they were not serving the counter they were just supplying the coolers and don't need to be GFCI. and really you can't answer his question unless we have a little more info about the coolers
#28 | |
![]() Trade: student again
Arc wears out contacts. Unlike switches, relays, or SWD breakers, contacts in GFCIs are not intended to be able to handle thousands of power interruption under load. Another thing is that the sensing system is all electronic, so power surge and such can destroy them. |
#29 | |
Unless listed as such. Switch-rated GFCIs are available.
#30 |
Re: Gfci Protection |
#31 | |
Trade: Electrical
#32 |
Re: Gfci Protection
so does this need to be gfci protected?
#33 |
Re: Gfci Protection
Yep; P&S catalog Nos. 2085x. Rated 1½ HP control rating.
#34 |
Re: Gfci Protection
Hmm, not sure if this means the same thing as SWD rated breakers intended to control lights in a gym as a switch.
Is this product rated to have the reset/trip buttons used as a switch to control the downstream load on a regular basis? |
#35 |
Re: Gfci Protection
I would say it could turn a 1½ HP motor on and off.
#36 | ||
Trade: Electrician
#37 |
#38 | |
Trade: Electrician
Re: Gfci Protection
210.8(A) is GFCI protection for dwelling units, 210.8(B) is for everywhere else.
#39 | |
Blame-Storm Mediator
Trade: MEP
So I forget where that came from honestly. I know here in So Cal it at least always used to be 5 devices after the GFI. I don't remember if that was a manuf. recommendation or I thought it was code. I just don't remember. I do I never had any problems with the line sticking to that rule. I guess what I meant by not for appliances was more for like undercounter fridges and freezers, GD's & DW's and etc. Motors and bigger appliances never seem to do well on GFI's was my recollection. |
#40 | |
Trade: Electrician
Re: Gfci Protection
The standards for both GFCIs and appliances have changed over the years - modern appliances shouldn't trip a GFCI unless there is a ground fault - in which case the GFCI is doing it's job.
| Kitchen - use 20A GFCI at start w/ 15A outlets??? | tmdelisle | Electrical | 25 | 07-28-2009 01:38 AM |
| AFCI Protection porject in class | electrichelper | NEC Discussion | 2 | 07-14-2009 07:31 AM |
| GFCI question | stp57 | Electrical | 6 | 04-18-2009 11:49 PM |
| GFCI protection for indoor spa/ hot tub | Magnettica | Electrical | 30 | 04-25-2008 10:05 PM |
| gfci and bathroom outlets | 72chevy4x4 | Electrical | 9 | 11-24-2007 09:11 PM |
