Gfci - Breaker Or Outlet?
Old 09-17-2009, 10:36 PM   #1
bob_cntrctr's Avatar
Trade: renovator
Gentlemen,
I'm dealing with an older place. Ungrounded outlets everywhere, including near sinks. Looking to do a little upgrade to at least gfci protection on outlets near kitchen and bathroom sinks.
I know I can go to gfci outlets IF I label them "No Ground", or I can go to gfci breakers in I label them "No ground" and "gfci protected" - but what are the pros and cons of each?
Breakers - expensive. What else?
Thanks.
bob_cntrctr is offline
Old 09-17-2009, 10:47 PM   #2
#1 stunner
Static Design's Avatar
Trade: Design/Build
Send a message via AIM to Static Design
Re: Gfci - Breaker Or Outlet?
So that's what those little stickers are for.
Will do autocad/ 3d work for food.
SD on facebook... click here
Static Design is offline
Old 09-17-2009, 10:55 PM   #3
Trade: renovator
OK, thought of one - if there's any knob and tube - ya, it's that old - the unbalanced load on the common return if there's more than one outlet on a circuit and both are used will trip the breaker every time.
Old 09-17-2009, 11:37 PM   #4
Fentoozler
Celtic's Avatar
You should become intimately familiar with 406.3(D) before making any decisions.
Celtic is offline
Old 09-17-2009, 11:48 PM   #5
And I do electrical, too!
480sparky's Avatar
Receptacles: Box fill may be an issue. If one trips, it may not be easy to locate if they're scattered hodge-podge around the house.
Breakers: May not be near by in case one trips. But at least you know where they all are. Multi-wires can be problematic. Also, did the breaker trip due to a ground fault, or an overload?
Site : the area or exact plot of ground on which anything is, has been, or is to be located.
Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision.
Cite : To mention in support, proof, or confirmation; refer to as an example.
480sparky is online now
Old 09-18-2009, 12:26 AM   #6
Master Electrician
Bubbles's Avatar
Trade: Electrical
Whichever you chose. This may help.
http://www.dummies.com/how-to/conten...al-outlet.html
I particularly like the perfectly labeled panel and the 1" of bare conductor he leaves on when rewires the recep. It's always a good idea to run all your current through a 0.32 rec. as well
good luck
Bubbles is offline
Old 09-18-2009, 07:54 AM   #7
Trade: renovator
406.3(D) is the reason for the question.
None of the receptacles actually need replacing, but I'm going to anyway, and so since these outlets close to sinks would require gfci outlets, that's what they're getting, as 406.3(D) requires.
And since 406.3(D) allows gfci's on non-grounded circuits so long as they're properly labelled, (in fact requires them at these locations) that's also what they're getting.
But 406.3(D) only requires that the new outlets be gfci protected. I don't believe it specifies that it must be gfci outlets, only that the receptacles be gfci protected an properly labelled, leaving open the possibility that they could be protected by gfci breakers instead.
Old 09-18-2009, 08:17 AM   #8
Pompass Ass
bwalley's Avatar
Originally Posted by bob_cntrctr View Post
Gentlemen,
Thanks.
Hire a licensed electrician, he will know what to do.
bwalley is offline
Old 09-18-2009, 02:43 PM   #9
Sparky760's Avatar
Trade: Electrical
good luck
Where do you find these people? LOL Pay no attention to that video unless you are looking for exactly what not to do. I almost spit my coffee all over my desk, thank you.
Go with the GFCI devices in the high use areas, Kitchen etc. and GFCI breakers every where else. It is a pain to go outside to reset the breaker all the time.
I've never done this, but I've seen a single ground run just to cover the kitchen outlets as a temporary solution. I suggest re-wiring the house as soon as you can.
Sparky760 is offline
Old 09-18-2009, 02:47 PM   #10
Doofenshmirtz Evil Inc.
JumboJack's Avatar
That would be a deal breaker.
in texas with framing and cornish people will do it for 3.00 a foot. What do yall think about that? Just laber
JumboJack is offline
Old 09-18-2009, 11:32 PM   #11
Fentoozler
Celtic's Avatar
I agree.
406.3(D)(3)(c) makes that pretty clear.
Originally Posted by 2008 NEC
406.3(D)(3) Non–Grounding-Type Receptacles.
Where attachment to an equipment grounding conductor does not exist in the receptacle enclosure, the installation shall comply with (D)(3)(a), (D)(3)(b), or (D)(3)(c).
(a) A non–grounding-type receptacle(s) shall be permitted to be replaced with another non–grounding-type receptacle(s).
(b) A non–grounding-type receptacle(s) shall be permitted to be replaced with a ground-fault circuit interrupter type of receptacle(s). These receptacles shall be marked “No Equipment Ground.” An equipment grounding conductor shall not be connected from the ground-fault circuit interrupter-type receptacle to any outlet supplied from the ground-fault circuit-interrupter receptacle.
(c) A non–grounding-type receptacle(s) shall be permitted to be replaced with a grounding-type receptacle(s) where supplied through a ground-fault circuit interrupter. Grounding-type receptacles supplied through the ground fault circuit interrupter shall be marked “GFCI Protected” and “No Equipment Ground.” An equipment grounding conductor shall not be connected between the grounding type receptacles.
Article 406: Receptacles
Oct 1, 2004 12:00 PM, By Mike Holt, NEC Consultant
You might be surprised to learn just how many rules are associated with these simple devices
Interesting one page article in EC&M by Mike Holt.
Celtic is offline
Old 09-18-2009, 11:35 PM   #12
Fentoozler
Celtic's Avatar
...to answer the OP's question:
Recept. or CB .... pro/con?
I would *probably* opt for the CB option.
If might cost more....
but having all the GFCI's in one place is the price paid for convenience......
granny isn't going to move the couch, TV, refrigerator, bed...etc.
Who knows exactly where the circuit originates?
Celtic is offline
Old 10-06-2009, 01:52 PM   #13
Ohmy's Avatar
Trade: Electrical Contractor
Rewire the house! Why put money into changing up something that's gonna need to be replaced eventually. Here we use breaker except in the bedrooms because we need arch fault breakers.
Ohmy is offline
The Following User Says Thank You to Ohmy For This Useful Post:
mrmike (10-06-2009)
weird gfci issue. im a noob! mechanix Electrical 24 08-04-2009 10:42 PM
GFCI breaker appears to be bad 72chevy4x4 Electrical 14 06-03-2008 12:11 PM
GFCI breaker vs GFCI Receptacle gravtyklz Electrical 14 10-20-2007 05:33 PM
t-shoot gfci breaker hurricaneflyer Electrical 10 11-14-2006 08:56 PM
gfci breaker Browny Electrical 6 05-29-2006 07:45 AM
