Gfci Breaker
Old 05-28-2006, 12:36 PM   #1
Browny's Avatar
Gfci Breaker
I have a customer I need to install a bathroom fan. He wants it in the above tub. So anyhow it says it needs to be protected by gfci. So I was going to install a gfci breaker. It seems the entire bathroom is on one breaker so I figure if I swap the breaker for gfci it would protect the entire bathroom. Is that proper?
I would greatly appreciate any help. I just like to make sure I am not doint anything half a$$ backwards when it comes to electric.
Thanks In Advance!
Browny is offline
Old 05-28-2006, 02:50 PM   #2
Electrical Apprentice
darren's Avatar
Trade: Electrical
Re: Gfci Breaker
I can't see why that would not do it for you, you should be good to go.
What i did when i wired my own bathroom was put the gfci and switch for my fan in the same device box. Live wires went into line side and oout of the load i connected the switch and then unto the fan.
Hope this helps
darren is offline
Old 05-28-2006, 02:53 PM   #3
mdcorreia's Avatar
Trade: Electrician - Self empl.
Re: Gfci Breaker
One has to make sure that the circuit can accept that additional load.
Most cheap contractors around here wire a home with the maximum of outlets in a circuit, therefore, anything added later has to be a new cct. I always wire a home with only 9 or 10 general outlets per cct.
mdcorreia is offline
Old 05-28-2006, 03:53 PM   #4
Browny's Avatar
Re: Gfci Breaker
Hope this helps
Yes I was thinking that cause I did put two gfci receptacles in already, one on each side of the medicine cabinet. the only thing is, its right in the middle of where switch and fan are going to be just on opposite side of room. SO i would be running all kind of wire. I was going to junction it right where power is comming into bathroom it to add additional line to the switch for fan. there is already a switch and line ran for light cause there is existing light that we are removing to put in new fan with light.
ON the circuit we will have lights at medicine cab, a fan and light combo, a light above commode and two receptacles.
Browny is offline
Old 05-28-2006, 03:56 PM   #5
mdcorreia's Avatar
Re: Gfci Breaker
Yes you have translate a bit!
Our code is varied a bit but not too much from the NEC
Old 05-28-2006, 06:26 PM   #6
Electrical Contractor
Speedy Petey's Avatar
Trade: Electrical
Re: Gfci Breaker
Browny, you are fine. As long as the whole room is wired with #12 on a 20 amp breaker.
The only thing I see is that you do have a bit of lighting, and two receptacles. Using more than one hair dryer will trip a breaker. That being said, just adding a vent fan will not tip the scales in either direction.
Speedy Petey is offline
Old 05-29-2006, 07:45 AM   #7
Electrician
fridaymean's Avatar
Trade: Electrician
Re: Gfci Breaker
Also, make sure the bathroom is not sharing a nuetral with another circuit. If it is, the gfi breaker will not work. You could just put in a gfi receptacle. That would save you some money.
fridaymean is offline
GFCI breaker seattle_sparky Electrical 24 01-25-2009 11:38 AM
GFCI breaker appears to be bad 72chevy4x4 Electrical 14 06-03-2008 12:11 PM
GFCI breaker RobertCDF Electrical 19 05-09-2007 06:56 PM
t-shoot gfci breaker hurricaneflyer Electrical 10 11-14-2006 08:56 PM
Breaker keeps popping DErnest Electrical 2 09-15-2006 06:30 PM
