Trade: GC residential/commercial construction
GFCI Alarm?
Never have been asked to solve anything like this, not my line of work. Your help would be much appreciated.
A commecial building with 4 heat tape/wire in 4 roof drains wired to 4 30amp GFCI's. The gfi's have tripped twice in 2 years causing damage to drain system. I need an alarm to sound when any 1 of the 4 breakers trip. A local supplier says to use a shunt and alarm in the panel to a gfi meant for the heat tape. Wouldent the gfi still trip before the shunt breaker does meaning no alarm would sound? He also said there is no GFI shunt, yet I see some stuff online from squareD using the words "ground fault alarm". sounds like what I need but the panel is seimmens. Is this a monitoring system solution or a breaker solution? I am not familiar with either under these circumstances. thanks, Charlie |
Trade: Electrician
Re: GFCI Alarm?
I have seen a couple of plug in style alarms to alert you when a GFI trips. I dont think any of the devices would help with what you need usually for residential purposes. You could set up an audible alarm pretty cheap with a small icecube relay and an annunciating horn.
Re: GFCI Alarm?
What you are asking for can be made a number of different ways. I really depends on how you want to be alerted and how kool of an alert you want to get.
One possibility is here. http://www.electronics-project-desig...lureAlarm.html Not all that cool but a start. Good luck!!! Have a good day. Les
ABLE1 |
Electrical Contractor
Re: GFCI Alarm?
I like the programmable relays myself. Has alot more capabilities than a standard relay and pretty inexpensive.
Omron has a nice one with 6 inputs and 4 outputs for around $90. That and an audible and/or visual alarm panel or remote mounted. |
Service & Repairs
Trade: Electrician
Re: GFCI Alarm?
The ground fault alarm you saw on Square D's website was probably for high impedance electrical system. I don't know too much about them but I remember reading about them in one of Mike Holt's books. I think what you need is what some of the others have led you to is a relay of sorts that sounds an alarm in the event the GFCI circuit becomes deenergized.
| Kitchen - use 20A GFCI at start w/ 15A outlets??? | tmdelisle | Electrical | 25 | 07-28-2009 01:38 AM |
| Load testing alarm batteries. | mdshunk | Low Voltage | 6 | 11-11-2008 10:41 AM |
| house alarm in trailer | cooks | Low Voltage | 7 | 10-24-2008 09:59 AM |
| GFCI Master not tripping | Mark Twenhafel | Electrical | 17 | 02-03-2008 06:08 AM |
| gfci and bathroom outlets | 72chevy4x4 | Electrical | 9 | 11-24-2007 09:11 PM |
