eastment
Guest
Posts: n/a
Garage - Protecting Wiring Installation
Hi all, new to this forum, first post.
Background: I live in Colorado, North of Denver. I'm building a garage/barn (pole building - metal siding/roof). I plan to install the all of the electrical and have a question about wiring protection. FYI - this is my first home/garage wiring project. Per NEC 300.4 "Protection Against Physical Damage" it states "Where subject to physical damage, conductors shall be adequately protected." Questions: 1. Since my building has a ceiling height of approximately 12', is it acceptable to run my wiring (NM sheathed cable) along the sides of the trusses/bracing/eave purlins etc. (all wiring to be run @ 11' to 12' above ground) without providing protection such as EMT,FMC, PVC, etc.? i.e. is a ceiling with all exposed framing and structural members typically viewed as an area that would require protection of wiring? 2. I was thinking I'd affix the NM to the wood members with plastic cable staples or U-shaped nails. If the answer to question #1 is "yes" then how would you affix the NM to the wood members in the ceiling? FYI, this building will not have any drywall installed; all framing and structural members are exposed. Thanks in advance or the response. |
eastment
Guest
Posts: n/a
Re: Garage - Protecting Wiring Installation
I apologize, this message should have been posted to a DIY forum, not this one.
Please disregard. Thanks. |
| Garage receptacle | ChuckEA | Electrical | 21 | 04-27-2011 07:45 PM |
| garage insulation | maderuyck | HVAC | 2 | 03-18-2007 12:43 PM |
| Flat roof over garage leaking under exterior walk out door | IHI | Roofing | 18 | 05-30-2006 10:28 PM |
| ...continued...garage floor drain progress | carlspackler | Plumbing | 0 | 05-27-2006 02:54 PM |
| Hot and cold water in the garage | Mike Finley | Plumbing | 18 | 12-06-2005 08:07 AM |
