Unregistered
Guest
Posts: n/a
Garage/basement Bedroom Wiring
I am finishing a basement bedroom. I have a circuit for the garage, with a circuit with "basement lights". The existing garage circuit feeds an outlet in the basement mechanical room. May I feed the future bedroom of this garage circuit, and convert the "basement lights" circuit into the new basement bathroom circuit?
Re: Garage/basement Bedroom Wiring
Need More Information on what you are trying to do. What Size Wire is feeding your current lighting? Is there a separate circuit feeding your garage?
If you can your best bet is going to be to run new circuits from your panel. New codes require all circuits in a bedroom to be Arc-Fault Protected. |
Administrator
Trade: Admin
Welcome to the board Hitek!
Nathan "He is no fool who gives what he cannot keep to gain that which he cannot lose." - Jim Elliot |
Electrical Contractor
Trade: Electrical
A new bathroom needs a 20 amp dedicated circuit. The whole bath can be on this circuit but no other outlets can. The receptacle needs to be a GFI. I would not GFI the whole bath, just the receptacle.
Unregistered
Guest
Posts: n/a
Gentlemen,
Sorry to have wasted your time. The sparkys failed to label the "basement lights" circuit as to what is is truly is, it's the basement lights & kitchen lights. So I am running a dedicated circuit for the bath. FYI, I was trying to shortcut by replacing the 15 amp "basement lights" circuit with a 20 amp, ( existing 12/2 wire) and renaming it the bath circuit. Just as a knowledge factor, would it have been compliant to pull the basement bedroom of the garage circuit? (20 amp, 12/2)? |
| inground pool wiring diagram | sparklito | Electrical | 3 | 01-13-2007 01:45 PM |
| Another aluminum wiring question | ron schenker | Electrical | 2 | 12-14-2006 09:22 PM |
| Master Bedroom Placement | ridgeline_dev | Remodeling | 4 | 05-09-2006 08:44 AM |
| Removing old wiring from conduit | duke | Electrical | 3 | 01-29-2006 11:04 PM |
| Garage - Protecting wiring installation | eastment | Electrical | 1 | 11-22-2005 02:52 PM |
