Keener Built Construction
A Funny One For You All.....
We are doing a job in Palo Alto - a large loft addition on existing that was designed by a "big name" architect.
Our carpenters already had to work around the architect's drawing the hips on existing roof in the wrong places. This architect also put can lights between skylights - if his print were correct, we would have 1' clearance between skylights. It is not, so we have 3". Why would they put can lights between skylights anyways??? I'm just planning on ignoring the outlet placed in the stairwell beyond anyones reach on the print.... |
#2 | |
Re: A Funny One For You All.....Quote:
Seems to me that although the architect has made errors, you ignoring what he wants on the plan and not questioning him if you think there might be an error , will come back to get you in the wallet afterwards.
Are you sure that you want to do that? It might be for something that will get mounted there. I know you're the GC and the EC both, but I hope you're sure about deleting that rec.
I will call the architect.
My husband and the architect are not working well together, something about 4 job stoppages due to mistakes in the print just doesn't have my husband too favorably disposed towards this architect. But he will probably talk to me. There is no longer any room for can lights! And we have lots of other lighting in the room, but I will just let him know. As for the outlet in the stairwell, well, it made no sense to me. But it would be easy to add it while I am doing outlets. |
How big is the stairwell. That recept. might make sense when you have to vacuum the stairs. Is there central vac in the project?
But it is a pretty standard sized stair well and there is no central vac. I will just do it anyways, it is no extra trouble. It just seemed funny to me, like what are they going to do? Watch TV on the stairs? I asked the homeowner about it and they had no clue as to why it was there.
Trade: electrical
Maybe for the night light for the kids? Maybe a switched PERMANENT night light??? Darn it, call the electrican!
Trade: Electrical
sounds like a good place for a clock
haha |
Union Electrician
Trade: Inside Wireman
I've seen wall mounted waterfalls in stairwells. I'd put the receptacle at the end of a run, so that it could be easily deleted if need be.
Philadelphia electrician
Trade: Electrical contractor
maybe it is for a magnetic coat holder?
... or a ferret trap? ... or to keep the leprechauns upstairs? [they are afraid to come within 42 inches of receptacles - didn't you know that?] |
Talked the homeowner into wall lighting at no extra charge, am heading out there in a little while to do that.
I was just going to put the outlet in the stair well anyways (Stair-mounted cordless phone base station?), but I guess I took too long on stuff and my hubby the GC put up SHEAR WALLS right where I have to run Romex - all along the side of the stairwell. He says this is normal if someone takes too long. Bullhockey, I'll bet half of you would have walked the job. I am having to take off the shear, sawzall cut out areas for junction boxes and replace the shear. I am just letting this one go. The homeowner doesn't want it, and also wasn't happy with a lot of things on the architects print. The homeowner signs my check. Enough said |
Trade: General/ Electrical/ HVAC/ Refrigeration/ IT Contractor
He put up walls before passing the electrical rough-in inspection? Here and Illinois all the walls would have to be ripped open completely.
What's a SHEAR wall? (SHEetRock?) |
It is most normal for any shear walls to have already been sheathed before my ruff. Smart Boxes are the key to an efficient ruff in shear assemblies.
Union Electrician
Why did the shear wall need to be removed? Just cut the hole with it in place is standard practice.
A shear wall is just plywood on one side of the wall beneath the sheetrock used for seismic bracing in earthquake zones |
Depends on where you live... I installed a sky light for a customer in the city... apparently the street light outside is in just the right place... she says she never uses the kitchen lights any more.
This is 3/8" plywood. I took it off so I could nail my wires properly - but couldn't get it off in some places so just used my trusty fish tape.
No - around here you put in boxes BEFORE shear is hung so wires can be stapled per code, then have ruff electrical, THEN shear inspection. I was busy on another job I was working on with our fav electrician - so hubby went ahead and hung shear. I HOPE I pass rough - the inspector may MAKE us take down all the shear I couldn't get off just so he can see the wire stapling (gulp). |
#17 | |
Union Electrician
I would imagine the inspector would want it down for electrical rough, kinda like a slap in the face for him don't you think. Come in to inspect and half the work is hidden??? Better get hubby in there and teach him the rules, or perhaps he likes doing it twice. If it's just one side of the wall like the shear walls I've seen then there shouldn't be any problem |
#18 |
There is one wiring method that is still 100% code-compliant to fish in bulidings under construction. Type FMC.
#19 |
Also, yes - near the staircase we have double shear. There is shear on one side on some of the walls and existing wall on the other. But I still had to go into the wall with shear to nail the wires off near the junction boxes.
Believe me - hubby has HEARD it from me!!!!! Pulling nails is not my idea of fun! Anyways, thank God I had the foresight to upgrade to a really good fish tape. |
| a little funny | go do it | Off Topic (Non Trade) | 0 | 07-01-2007 03:22 PM |
| funny clients | Afford-Handyman | Electrical | 10 | 11-01-2006 11:13 PM |
| Funny car fans? | Mike Finley | Off Topic (Non Trade) | 8 | 07-17-2006 11:40 PM |
| LMAO!! too funny. | IHI | Off Topic (Non Trade) | 3 | 04-07-2006 10:39 PM |
| Very funny..... | Always Greener | Off Topic (Non Trade) | 3 | 03-25-2006 05:20 PM |
