tags, as close as possible to the opening tag. Creation Date: 12/20/2017 -->
Fluorescent Light Problem
Old 09-19-2017, 05:48 PM   #1
nickko's Avatar
Trade: remodeling-cabinet maker
Rewards Points: 691
i installed some cheap Lowes fluorescent lights in a basement today. There are four lights with two tubes each. The guy already bought the lights and they are plug in type, not hard wired. So i installed some plugs in the ceiling and installed the lights and plugged them in. All eight bulbs look like they are swirling around inside and flickering. What would cause such a thing?
His son installed the same lights in another part of the basement the same way and his do not swirl and flicker. These are installed in conjunction with an old ballust type light. could the old ballust light be causing the swirling in the new lights? but his son has the same situation where he installed the lights also in conjunction with an old light and has no swirling.
thanks.......nicko
"Quality work for those who know the difference"
nickko is offline
Old 09-19-2017, 05:54 PM   #2
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 10,080
Re: Fluorescent Light Problem
Fluorescent lamps use a small amount of mercury vapor to operate. However, it is not vapor that is installed at the factory. It's just a drop of liquid mercury. It takes up to 48 hours of operation to full vaporize the mercury.
Just let the lights run for a couple days.
Chuck Norris can cut through a knife with hot butter.
480sparky is online now
Old 09-19-2017, 05:56 PM   #3
tjbnwi's Avatar
Rewards Points: 1,702
Check the ballast labeling, make sure they picked up the right bulbs.
tjbnwi is online now
Old 09-20-2017, 03:43 PM   #4
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 5,641
Temperature difference, the A.C.- ed part of the basement has dimmer bulbs?
B. lower input line voltage check outlets while running....loose breaker?
Fouthgeneration is offline
Best 12V cordless drill LIGHT ??? lewisthepilgrim Tools & Equipment 10 12-19-2013 10:11 PM
Light activated exterior lighting wallmaxx Electrical 9 05-10-2013 05:50 PM
problem with a large order of pond products Outdr Contractr General Discussion 6 12-20-2012 07:51 AM
How many forum members to change a lightbulb? Al Truistic Off Topic (Non Trade) 48 11-09-2008 01:46 AM
How many members of CT does it take to change a light bulb? Bill Off Topic (Non Trade) 19 01-05-2008 01:13 PM
