Flat Panel TV - Power Outlet Issues
Old 12-22-2008, 01:52 AM   #21
SoCal electrician
Hidyusbeast's Avatar
Trade: electrician
Re: Flat Panel TV - Power Outlet Issues
here another issue : the plug should be either a surge protected receptacle or protected by a surge protector somehow. If they have a nice flat panel tv this is cheap insurance. What able any cables such as a hdmi cord or a clean power surge device. There are many types of ways to do things but above all it is probably worthwhile to hire a good electrician.
Hidyusbeast is offline
Old 12-24-2008, 10:53 AM   #22
mike01's Avatar
Trade: Electrical
Typically we see clock receptacles for this purpose but now pass and Seymour has come up with a nice way to address this problem (See link below): sorry cannot post link until I have made 15 post so check out pass and seymour recessed tv box. You can also get a tvss rec.
mike01 is offline
Old 12-26-2008, 02:37 PM   #23
duckdown's Avatar
Trade: Home Theater
His original description of a "special" outlet is about using the outlets that are recessed into the wall. Using regular outlet's makes it difficult to plug into especially if the idea is the TV will be covering it.
You can use "conduit" to bring wires up a wall to the height of the plasma but that of course assumes that you like the look and more importantly that the outlet is directly below where the TV will be placed.
Since I focus on the higher end, I almost always place an new outlet vs using conduit track.
duckdown is offline
Old 12-26-2008, 03:58 PM   #24
Handle It!
MALCO.New.York's Avatar
Panduit.
http://www.panduit.com/Products/Prod...iews/index.htm
Ultimate Wisdom---------
MALCO.New.York is offline
panel in guest house veer Electrical 15 08-10-2008 05:42 PM
I find some of these names,shocking sjm Painting & Finish Work 7 08-20-2007 06:51 AM
Sub panel mjay Electrical 9 02-24-2006 11:41 PM
How many Breakers in a panel robertc65 Electrical 2 02-21-2006 02:09 PM
Dirty Power Problem In One Outlet?? Johnny916 Electrical 12 02-08-2005 12:18 AM
