The Deck Guy
Exterior Recessed Lights?
I'm speccing out an under deck ceiling/drainage system. The HO wants lights in it.
This "ceiling" is actually a huge water collecting system. Any light installed into it would be essentially flooded with water. Does such an animal exist?????
Re: Exterior Recessed Lights?
maybe some kind of underwater pool light
They couldn't live with puck lights
of some sort? Never mind...wire penetrations.
Professional Instigator
Re: Exterior Recessed Lights?I actually thought about posting that. The problem with those and most exterior recessed lighting they are water proof or prevent water from coming in in the front. from the back they are useless or prone to failure |
Sean
Pool Light = mega heat
What type of drainage system are you planning on? IC Recessed light sealed around wire opening with silicone or??? |
Trailer park boy
2 panels in the joist spaces where the lights will go, one up high to catch the water and extend past the location of the light, the lower one can hold the light?
You'd have to frame a ceiling below your ceiling and put regular recessed lights in it.
They do make "wet niche lights", but you're almost guaranteed a leak. |
MD, what if in the process of building the deck one was to frame out some sort of waterproof box in the joist bays where the lights were going to go?
Service & Repairs
Trade: Electrician
Is this discussion really about mounting a light in a pool of drainage water or is it just me?
Any pictures of this job? |
#10 | |
Capra aegagrus
Re: Exterior Recessed Lights?Quote:
Then he wanted to control it while sitting in the tub, so I set him up with a remote controlled ceiling fan dimmer with the receiver mounted inside the house. Then he wanted to know how he could tell if there was any electricity in the water. I told him "Throw a fish in and see if it floats belly-up." The light still works. I haven't had any fish reports. |
Trade: ELECTRICAL
why dont u recess a water-proff strip with a plastic cover same like they use in walk in fridges
Trade: Specializing in residential remodeling
Wet niche's won't fly for this application...is it possible that the H/O will except either low voltage like LED or fiber-optic? I just bought a submersible LED light that can be installed without be submerge in water.
| Would this cause the lights to flicker? | mickeyco | Electrical | 6 | 09-10-2008 09:45 PM |
| cutting holes in aluminum soffit for can lights | buckeyeso2 | Windows, Siding and Doors | 18 | 08-26-2008 01:59 AM |
| Wiring shop lights. | ryan.s | Electrical | 14 | 04-10-2008 11:17 PM |
| Installation Of recessed lights | Morry | Electrical Picture Post | 20 | 07-20-2007 09:56 PM |
| Digging Under The Lights? | denick | Excavation & Site Work | 9 | 02-28-2007 06:52 AM |
