Exhaust Fan
Old 09-07-2008, 05:07 PM   #1
MSSI's Avatar
Trade: Electrician
Exhaust Fan
Is a Fart fan a code requirement for a powder room?? (no shower/bath) and no window.
This is for a Relo company inspection. The fart fan is not vented properly.
My suggestion is take it out and patch the hole rather Than tearing several walls apart to vent it properly...
Thanks
MSSI is offline
Old 09-07-2008, 05:23 PM   #2
Professional Instigator
rbsremodeling's Avatar
Re: Exhaust Fan
Thanks
You could put in a ventless fan. They use a charcoal filter
rbsremodeling is offline
Old 09-07-2008, 05:49 PM   #3
mdshunk's Avatar
Re: Exhaust Fan
A bathroom is required, by code, to have either a window or a fan vented to the exterior. Lacking a window, there is no exception that will permit the use of the vent-free fan.
mdshunk is offline
Old 09-07-2008, 06:14 PM   #4
MSSI's Avatar
Trade: Electrician
Re: Exhaust Fan
*Even though the house was built in 1971 ???
*Does the homeowner have any sort of arguement??
Thanks again
MSSI is offline
Old 09-07-2008, 06:23 PM   #5
mdshunk's Avatar
Re: Exhaust Fan
Who knows. All I know, for sure, is that if there's no window, it needs to be vented to the exterior if you were doing the work today. If this is just an ordinary home inspection, the neither the buyer or the seller has to do any of the work the home inspector finds if they don't want to. The home inspector just writes down a list of observations. Nothing legal can compel the owner to "fix" any of that stuff.
mdshunk is offline
Old 09-07-2008, 07:48 PM   #6
Service & Repairs
Magnettica's Avatar
Trade: Electrician
Re: Exhaust Fan
I believe the window/bath fan thing is a requirement of the Mechanical Code.
Magnettica is offline
Old 09-07-2008, 08:13 PM   #7
mdshunk's Avatar
Re: Exhaust Fan
It's there too, but it's mirrored word-for-word in the IRC.
mdshunk is offline
Old 09-07-2008, 10:18 PM   #8
genecarp's Avatar
Re: Exhaust Fan
Thanks again
you can always try, catch the right inspector on the right day, and you could put an outlet in a shower
genecarp is offline
Old 09-07-2008, 11:02 PM   #9
Union Electrician
Reseman's Avatar
Trade: Electricial Contractor / Electrician
Lightbulb
Re: Exhaust Fan
Thanks
Article 100 states that a bathroom is an area including a basin with one or more of the following: a toilet, a tub, or a shower. If the powder room has a basin plus one of these items then it needs some sort of ventilation.
Make sure to do the installation correct.....because it will bite you in the ass if you don't.
Reseman is offline
Old 09-10-2008, 10:40 PM   #10
Union Electrician
Sparky Joe's Avatar
Trade: Inside Wireman
Re: Exhaust Fan
explain "not vented properly"
As I understand a typical attic is vented to outside air, thus a fart fan venting to the attic can be considered vented properly.
Of course this is not standard practice, but when ideal conditions are not present it may be the only option?
Sparky Joe is offline
Old 09-10-2008, 10:49 PM   #11
Teetorbilt's Avatar
Re: Exhaust Fan
I would think that most folks would WANT a fan.
I have seen closet/powder room conversions without them but could not tell you when they were done.
Albert Einstein
Teetorbilt is offline
Old 09-10-2008, 11:06 PM   #12
mdshunk's Avatar
Re: Exhaust Fan
Actually, if it doesn't terminate outside, it's a code violation. If a fan is code required, it must terminate outdoors. If you have a window to get your code compliance, then the fan is now optional and you can terminate the exhaust however you want to.
mdshunk is offline
Old 09-10-2008, 11:34 PM   #13
Union Electrician
Sparky Joe's Avatar
Re: Exhaust Fan
Thanks MD,
I have been instructed in the past to "just run it half way up one of the rafters".
Asking if that was legal I was given that explanation of "attic air is same as outside air"
Of course I wondered why others went the lengths of penetrating a watertight exterior, but so long as I raised the question it was off my conscience.
Old 09-10-2008, 11:56 PM   #14
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Re: Exhaust Fan
[quote=mdshunk;493104]Actually, if it doesn't terminate outside, it's a code violation. If a fan is code required, it must terminate outdoors. If you have a window to get your code compliance, then the fan is now optional and you can terminate the exhaust however you want to.[/quote]
You sure about that? I'm under the impression it can't terminate in the attic (or soffit anymore around here), no excuses.
Mike Finley is offline
Bathroom exhaust fan and minimum distance from shower Dustball Electrical 9 05-05-2010 10:12 AM
dryer exhaust vs. barn swallows cleveman HVAC 8 08-29-2008 08:20 AM
Exhaust fan for attic Handyman Construction 22 10-22-2007 11:18 PM
