tags, as close as possible to the opening tag. Creation Date: 12/20/2017 -->
Estimate Material Cost For Rough-in
Old 03-05-2011, 01:22 PM   #1
UpNorth's Avatar
Trade: Engineer & Ret. GC
A story and a half house, 3 bedrooms, 2 baths, laundry room, will be built over a 4-foot depth crawlspace. Here is my rough-in estimate for cost of materials. Where am I wrong, and what am I missing. The power is run to the barn already, and will run an additional 60 feet underground to get into the new house.
Wire, including service in from barn: $2,000
Workboxes, related hardware: 250 (total 81 openings)
Panel, breakers: 250
Can lights (no trim): 150
Bath vent fans, duct: 300
Smoke, CO detectors 150
Misc. 150
Total: $3,250
UpNorth is offline
Old 03-05-2011, 01:29 PM   #2
Sparxx's Avatar
Trade: Electrical
Rewards Points: 25
Re: Estimate Material Cost For Rough-in
Does that estimate include labour? I find using estimating software and then adjusting the cost to reflect the particular job a good starting point.
If you don't have it I believe it's the National Electrical Estimator 2011 (US version). I'm fairly certain there's a free trial.
Sparxx is offline
Old 03-05-2011, 01:32 PM   #3
General Contractor
greg24k's Avatar
Rewards Points: 7,358
Let's see...Hmmm
greg24k is offline
CENTERLINE MV (03-05-2011)
Old 03-05-2011, 01:36 PM   #4
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
You are not even close, arc fault breakers will exceed your budget for panel and breakers alone. Staples, wire nuts, and oh yeah, about $6000 in labor.
http://www.ohiohomedoctorremodeling.com
ohiohomedoctor is offline
Old 03-05-2011, 02:05 PM   #5
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 10,500
AFCIs? GFCIs? Only three smokes? TR receps? $3 per opening for boxes & devices means no dimmers, 3- and 4-ways. Permits & inspections? Insurance?
I gotta tell ya.... this looks exactly like a HO's math.
Why is there not a Flat Mars Society?.
480sparky is online now
The Following 2 Users Say Thank You to 480sparky For This Useful Post:
greg24k (03-05-2011), Seven-Delta-FortyOne (03-05-2011)
Old 03-05-2011, 02:09 PM   #6
UpNorth's Avatar
Who says I need AFCI breakers?
This estimate is for the rough-in only. No switches, no receps, no devices of any kind are included.
I might be a little low on my panel and breakers number, but not much. See attached for an idea. Panel including some of them, $165. Twenty more 120s @ $4 and two more 230s @ $13. I'll raise my $250 to $300.
And (oh, yeah!) labor is free, 'cause it's by me. See, I'm a poet, and I didn't know it.
No contractors are licensed here, nor are they required to do so. A friend who owner-built and did all this will advise and assist if required. His job included his two new buildings, with a three-phase power feed due to the machinery requirements in his ultimate cabinet shop with large stationary power equipment.
I gotta tell ya.... this looks exactly like a HO's math. And it is, by a HO that does not intend to hire a pro, and does not need to. This ain't rocket science.
Estimate material cost for rough-in-2011-03-05_1454.png   Estimate material cost for rough-in-2011-03-05_1456.png
UpNorth is offline
Old 03-05-2011, 02:49 PM   #7
Electrical Contractor
Speedy Petey's Avatar
Trade: Electrical
Rewards Points: 1,244
The NYS Resi code and the NEC, that's who!
Unless of course you will be ignoring those and are not getting anything inspected.
This continues to be one of the stupidest statements EVER regarding electrical work.
Sure, any hack can nail up boxes and string cable. But it takes someone who knows what they are doing, and someone who cares about doing it right, to do a proper job. Which one are you???
Speedy Petey is offline
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
Old 03-05-2011, 02:52 PM   #8
Trade: Electrical
You wanna know the accurate way to price the material only for a rough-in?
Buy all the material plus extras. Use what you need and return the rest, just like every other DIY home depot customer. The subtract receipt two from receipt one. THAT is your material cost.
Old 03-05-2011, 02:54 PM   #9
480sparky's Avatar
If it's so easy, let's see you rough it in in two days. By yourself. No 18-hours days, either. Alone, get it done in 16 hours.
Old 03-05-2011, 03:01 PM   #10
UpNorth's Avatar
My last build was just before this new code took effect.
NY is now saying, Section J608.4, Ground-fault and arc-fault circuit-interrupter protection, states: Ground-fault and arc-fault circuit-interrupter protection shall be provided on newly installed receptacle outlets as required by Section RE3802.
And thus, the estimate is increased by $800 to now include AFCI breakers. Total rough-in materials now estimated at about $4K.
The local BI cannot inspect electrical, and to do the final for a CO, requires that the sparky work be inspected by one of the independent pros that do that. The same guy that did my friend's very-professionally-done house plus shop plus warehouse plus guesthouse will inspect this, and his fee for doing so is not included in this rough-in-materials cost.
Rocket science is rocket science, and requires years of study and field work. Think aeronautical engineering at the Ph.D level. Residential wiring can be learned from a book from the library, and in a little less time. Relax, we'll get this done just fine. And all the plumbing, too.
UpNorth is offline
Old 03-05-2011, 03:06 PM   #11
480sparky's Avatar
Just remember.......... you are the one that's going to be living in it.
Old 03-05-2011, 03:15 PM   #12
Trade: Electrical
Of course it does not include material. In NYS, electrical contractors, or "independent pros", DO NOT do electrical inspections. Approved third party electrical inspection firms do.
That's funny. So does electrical work.
The rocket science comparison is still uber lame.
Oh, and BTW. That book you got from the library was probably recalled due to improper and dangerous information. Just sayin'.
Old 03-05-2011, 03:17 PM   #13
Trade: Electrical
http://www.cpsc.gov/cpscpub/prerel/prhtml10/10104.html
The Following User Says Thank You to Speedy Petey For This Useful Post:
Old 03-05-2011, 03:27 PM   #14
UpNorth's Avatar
I should have said, "the same guy that inspected my friend's work."
Yeah, my friend, not an electrical pro, who did all his wiring himself.
You guys are almost as bad as plumbers. An over-the-top sense of self-worth, and quick to pull the nasty trigger on a property owner seeking to self-build. As if we're all incapable neanderthals.
Lighten up. You coulda been a rocket scientist if you'd sat in the front row, instead of sitting in the back, throwing spitballs. You've absolutely no idea of how capable of doing this we are. Our electrical inspector will be consulted before we plan out our details and go to ordering materials.
We are just trying now to budget out our costs, thus the question here on this forum.
UpNorth is offline
Old 03-05-2011, 04:31 PM   #15
480sparky's Avatar
...........You guys are almost as bad as plumbers........
Yep, plumbing is easy...... cold on the right, sht runs downhill..... that's all there is to it!
....... Our electrical inspector will be consulted before we plan out our details and go to ordering materials. ............
This statement right here blatantly shows how inadequate and unprepared you truly are... thinking an inspector is going to assist you in preparing a material list and laying out your work. How absolutely laughable.
Did the Chamber of Commerce do your load calculations for you? Oh, wait...... have you done a load calc?
The Following User Says Thank You to 480sparky For This Useful Post:
Speedy Petey (03-05-2011)
Old 03-05-2011, 04:45 PM   #16
Sparxx's Avatar
Trade: Electrical
Rewards Points: 25
My father has been an aeronautical engineer for decades and has a great appreciation for the vast knowledge that is required in my trade to service all sectors of industry.
I wouldn't belittle your profession (whatever it may be), but it scares me you're doing an electrical install when you're incapable of doing a proper quote for a simple R/I - nevermind the actual wiring AND in accordance with the NEC.
Maybe someday one of our fellow tradesman will get to post your work in the WTF? Picture Post....
Sparxx is offline
Old 03-05-2011, 04:48 PM   #17
480sparky's Avatar
Originally Posted by Sparxx View Post
...... Picture Post....
This work for you?
bauler (03-06-2011)
Old 03-05-2011, 05:02 PM   #18
Sparxx's Avatar
Trade: Electrical
Rewards Points: 25
You pulled the image right out of my mind 480!!!
Just read your last post Hack...I sat where I damn well pleased and it didn't seem to have any adverse effect on me getting my masters in ME or my degree in ID. I think your comments regarding "self worth" are misplaced - ever think people take pride in their careers and find it offensive when people as evidently ignorant as yourself make snide remarks?!
Sparxx is offline
Old 03-05-2011, 05:10 PM   #19
480sparky's Avatar
I want to build a deck, so I composed a material list.
2x4s, 2x6s, 2x8s, 4x4's....ah, $400 sounds good.
5/4 decking........ $300.
Nails & screws...... $75
Misc........ $50.
Sound right?
I'm going to convert a large closet into a half bath, so I need:
1 toilet...........$50
1 vanity.........$100
1 top..............$75
1 faucet..........$25
Did I miss anything?
I'm going to remodel my kitchen next week.
Lessee, I'm thinking $2000 in cabinets, $1000 should cover the countertops, new appliances,...... $1500 should get them.
Anything else? Oops..... I forgot $10 for screws.
Old 03-05-2011, 05:17 PM   #20
Sparxx's Avatar
Trade: Electrical
Rewards Points: 25
Misc........ $50.
Sound right?
Anything else? Oops..... I forget $10 for screws.
damn you 480!!! I just cracked open a nice cold one and now it's all over my desk...:laughing laughing laughing:
you forgot drawer handles and a mirror for the bath, about $5
Sparxx is offline
Time To Really Consider Escalation Clauses Ed the Roofer Business 19 02-17-2017 10:25 PM
How do you run your estimate, what do you give the customer and when? starcontractor Marketing & Sales 16 06-01-2009 09:13 AM
Material Prices and poor economy J-Peffer Roofing 16 03-04-2009 11:39 PM
Material Cost Ozark Barns General Discussion 5 10-26-2008 05:24 PM
how much cost material for 2000sf house milos General Discussion 13 01-17-2007 11:01 PM
