Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Electrical
Old 09-12-2009, 08:17 PM   #1
huntington beach, ca.
Trade: electrical
Entry way 2 hour override switch...
I need a 2 hour override for lighting in medical building, lights operate off a 20 amp contactor. I have no idea where to start looking...something push button would be nice.
hbelectric is offline   Reply With Quote
Old 09-12-2009, 08:30 PM   #2
Electron Flow Manipulator
480sparky's Avatar
Trade: Electrons for cash
Leviton 6652-1I.
Age is just a number but mine is unlisted.
480sparky is online now   Reply With Quote
The Following User Says Thank You to 480sparky For This Useful Post:
hbelectric (09-13-2009)
Old 09-13-2009, 06:42 AM   #3
mrmike's Avatar
Trade: Electrical & Carpentry
I'm thinking you have many lights to operate, as you said they were on a 20 amp contactor so you will need a timer with heavy duty contacts............. If you want a push button type switch?, you will have to wire it to pull in a timer relay to operate that 20 amp contactor. Need more Specifics !
mrmike is online now   Reply With Quote
Old 09-13-2009, 07:42 AM   #4
480sparky's Avatar
I'm gonna say it's the lighting circuits that are 20 amps, not the coil on the contactor. I've never seen a lighting contactor coil draw more than an amp.
Old 09-13-2009, 08:11 AM   #5
Trade: GC/Remodeling
Similar situation..folks place.
Have a gas well that needs saltwater pumped periodically..as needed. We have a pressure switch on a volume tank that will start it..but it needs to run for like an hour after the pressure comes back up.
Timer won't work... need some thing like a relay w/delay?
Originally Posted by jeremy-lvhm View Post
...just stop it. go sit down and have a lollipop and think about what your saying.
TimelessQuality is offline   Reply With Quote
Old 09-13-2009, 12:42 PM   #6
BTE
Trade: Electrical Contractor
Sparky is right. If you install just a push button, you'll need to install some type of timing device that hooks up to a 7-day timer. It is best to install a twist timer that mechanically times itself out that is wired to a lighting contactor.
BTE is offline   Reply With Quote
Old 09-13-2009, 12:47 PM   #7
Trade: electrical
I'm using the 365 day time clock on the right in the picture, so basically you are saying this levinton 6652 push button, will most likely need a relay to close the lighting contactor. If this is the case, not a problem.
Old 09-13-2009, 01:22 PM   #8
Professional Remodeler
firemike's Avatar
We used to use something like this in the stores we did. just a simple off-delay relay that controls the coil of the contactor.
http://www.grainger.com/Grainger/items/1EJP3
Turn the light switch off and the contactor turns the lights off after predetermined amount of time (ie. Give the employees enough time to get out of the building before all the lights went off)
-Mike-
Falcon Contracting
Residential - Commercial
firemike is offline   Reply With Quote
Old 09-13-2009, 01:51 PM   #9
480sparky's Avatar
You can put the 7-day timer and the 2-hour switch in parallel with each other. That way, either one will turn on the lights as needed. Run them with the same circuit to control the same relay.
Old 09-13-2009, 02:29 PM   #10
Trade: electrical
Yeah I understand, I know some of these timers won't close contactors. But this one says its good for inductive loads/motor loads.
Old 09-13-2009, 03:45 PM   #11
mrmike's Avatar
???? Lighting circuits are never across the coil of the Contactor. The lighting is across the contacts of the Contactor. The coil is usually pulled in by a relay or remote switch, etc- most times thru a Photocell. We had multiple outside area lights turned on by one contactor with just one photocell to turn them on.................
Old 09-13-2009, 04:03 PM   #12
480sparky's Avatar
I think we said the same thing.
It's the lighting circuits that use 20 amps, not the coil. Sometimes it's the same circuit, but the coil won't use 20 amps when pulled in.
Old 09-15-2009, 08:08 PM   #13
ampman
ampman's Avatar
Trade: providing pathways for electrons and protons
this is what is needed timers will need to be reset in the event of a power outage unless they are battery backed up ,make it to complicated and "employees" will not get it
T.Boone Pickens " by buying foreign oil we are funding both sides of the war "
ampman is offline   Reply With Quote
Switch Loop Problem CookeCarpentry Electrical 43 04-12-2009 08:49 PM
Multiple fixtures on switch loop KenHaynes Electrical 2 12-05-2007 03:15 PM
Dimmer switch blowing out glock40 Electrical 4 03-13-2006 07:54 PM
smart light switch circuit toastermaker Electrical 7 12-07-2005 11:45 PM
