Trade: electrician
English 3ph Db Losing Neutral Connection
we have had a instance where a 3 ph db has lost its neutral and has spiked the 240v single phase side damaging the ups and fluorecent fittings, is this possible? and would you get a higher voltage down the sp side?
Trade: Electrical: industrial, commercial, power generation, controls
Re: English 3ph Db Losing Neutral Connection
A lttle more info, and maybe I'll have a suggestion-
Global warming? -- Bring it on!!! Last edited by alaskafunboy; 11-28-2006 at 06:17 AM. |
Yes, it is possible. That's what happens when you have an open neutral.
Trade: Licenced Electrician
Yes, very possible. If you have circuits that share a neutral and the neutral breaks you will get full voltage to the devices. If your main neutral breaks, all the circuts are affected.
Line 1 to neutral = 120v Line 2 to neutral = 120v Line 1 and 2 sharing a neutral Neutral breaks ! Line 1 to line 2 = 240v Acts like a series circuit, voltage at each device depends on it's resistance. |
| 55 volts on both hot and neutral, what the heck!? | karma_carpentry | Electrical | 32 | 02-28-2009 09:12 AM |
| Need help with a shocking outside waterspout | Badoish | Electrical | 23 | 12-27-2008 04:18 PM |
| Reverse feed a broken neutral - K & T wiring | mdcorreia | Electrical | 3 | 04-06-2007 06:53 PM |
| Shared neutral with a GFI | darren | Electrical | 21 | 03-03-2007 06:38 PM |
| breaking the neutral..GENNY INSTALL | snapperhead | Electrical | 4 | 07-05-2006 10:58 PM |
