Emergency Question From A Lowly Carpenter
Hello all,
We are supposed to get 90mph winds tomarrow . so, I am trying to get my generator rigged to run the house. I purchased a home this year that already has a seperate generator panel with a 20 amp input (obviously designed for a 5000wat generator). The problem is that I have a 7500 wat generator with a 30amp outlet. So, is it safe to plug a 30 amp rated generator into a 20 amp generator panel?30amp gen outlet -------------> 20amp panel. I know the reverse would not work as the cord would not be protected, but in this case wouldn't the 20amp breaker trip if the house attempts to draw more than 20amps from the generator? Thanks in advance |
Re: Emergency Question From A Lowly Carpenter
ETA: nevermind the manufacturers tech support finally called me back and said it's a no go.
Electrical Contractor
Trade: Electrical
Can you let us know what site said that?
Trade: Electrical & Carpentry
probably the reason they said it was a No-No is becuase the 20a L1420 male plug & wire on the generator transfer panel would not be protected by your 30 amp circuit breaker on your 7500 watt generator,where it would be on a generator up to 5000 watt with a 20a breaker. I am not sure if you could upgrade that 20 amp plug & wire on your transfer panel to a 30 amp L1430. I would like to know myself, so I hope someone has input here.
In an emergency You could temporarily put a L1420 female plug on your 30 a cord to use it as is.with your generator.. The individual breakers on the transfer panel are protecting the circuits, so you just have to keep the sum of them under 20 amp to protect the plug and wire on the panel, until you get it updated.. Hope this helps. |
It wasn't a site that said it was a no go. I left a message with their tech support dept. and a lady called me back to say that the "system" wouldn't be protected.
Professional Instigator
hook the generator directly to the panel
bump Last edited by rbsremodeling; 12-19-2008 at 08:11 PM. |
Trade: Electrical
Does your 20 Amp panel have a main breaker? A 20 Amp breaker?
If so, then make your cordset with a 20 Amp NEMA L14-20 end on it, and use it! You should be good to go. |
Trade: Residential Remodeling
I am thinking that the lady meant the electrical line system wouldn't be protected and he would be feeding live voltage while the guys would be working on the line unless there was a transfer switch involved.
updates:
the panel does not have a main 20amp breaker (unless it is internal and I can't see it). It has a 15amp breaker for each circuit. It is a manual transfer switch so I am confident that linemen will be protected. Also, it has a watt meter to show how much power you are drawing, so I am thinking that I can rig it up and just make sure that the watts never go over 5000. Correct? |
#10 | |
Fentoozler
Re: Emergency Question From A Lowly CarpenterQuote:
![]() So how exactly does it transfer itself when utility power is restored.....at 3AM?
it doesn't transfer itself. Each circuit is run through the transfer switch and each circuit has a manual switch: GENERATOR---OFF---LINE POWER.
Fentoozler
So how will the linemen be protected from your generator when they restore power at 3AM?
Service & Repairs
Trade: Electrician
You need a transfer switch to manually switch from utility company power to generator power.
Re: Emergency Question From A Lowly CarpenterManual Transfer Switch Product Information A. What is it? The EmerGen Switch provides a method to safely utilize generator power through your existing electrical wiring during a power outage. You’ll install this switch next to your home’s load center and connect the transfer switch’s wires to specific circuit breakers. Once you power up your generator, you will manually transfer that generator energy through the circuits you have chosen. B. Why use it? A portable generator supplies power for one or more extension cords. This same generator, when plugged into a transfer switch, will provide power to the existing wiring circuits, eliminating the need for extension cords. C. How is it safe? A transfer switch contains the switching which isolates the utility-supplied power from the generator-supplied power. Because of the unique design of the transfer switch, these two power sources cannot be ON at the same time. The transfer switch prevents “back-feeding”, a very dangerous situation where power flows back through the circuit breaker – usually the main breaker in the load center – and into the power supply from the utility and cause electrical equipment to fail, or worse yet, cause hart to line-maintenance personnel. By properly wiring the transfer switch and controlling the switches, safety is assured It works like every other manual transfer switch I've seen see line "C" in the link above (can't post the url w/o 15 posts) |
Trade: GC/Remodeling
So....what about a transfer switch? Pretty sure you need one
-Steve "The most beautiful thing we can experience is the mysterious. It is the source of all true art and science." ~ Albert Einstein |
#16 | ||
Fentoozler
I understand you all wanting to make sure the linemen don't get zapped, that would be a bad day.
What about the plan of using a 20amp plug on my 30amp Generator cord to connect to this panel? If I keep the load under 5000 watts will the 20amp plug and wiring be safe? |
#18 |
Service & Repairs
Trade: Electrician
As long as the 20 amp cord body is protected by a 20 amp breaker I don't see any problems.
However, try as you must, you'll never get close to using 5000 watts without first tripping the circuit breaker. What kind of crap do you expect use when the power goes out? |
#19 | |
Insert title
Trade: Doors-Windows-Decks
To get the best replacement windows, or sun rooms contact the replacement windows experts at FHI Vinyl Window Company. |
#20 | |
That's the problem, the 20 amp plug (on a 30amp cord) would not be protected by a breaker. I only want to run a gas furnace and four 60watt light bulbs |
| Question from lawyer trying to help contractor | scp | Business | 52 | 02-25-2011 01:23 AM |
| Question for GC re: rough/final cleans | britanie | General Discussion | 6 | 06-07-2009 07:42 PM |
| poem about an old carpenter. | healthyhomes | General Discussion | 5 | 08-30-2008 09:38 AM |
| Carpenter tells HO to install floor first | Frankawitz | Flooring | 12 | 03-02-2007 06:50 PM |
