Elite Miracle One Gate Operator Problem - Electrical - Contractor Talk
Old 11-30-2009, 07:56 PM   #1
wlcm2ericcntry's Avatar
Trade: plumbing
My elite miracle one gate operator has recently stopped working correctly. THe gate begins its motion but half way in its track the gate stops and the reverse safety alarm takes effect. When opening and closing the gate manually it is also very diffucult. Any ideas what is wrong?
wlcm2ericcntry is offline
Old 11-30-2009, 08:00 PM   #2
Service & Repairs
Magnettica's Avatar
Trade: Electrician
Rewards Points: 2,002
Re: Elite Miracle One Gate Operator Problem
The reverse safety alarm is malfunctioning.
Magnettica is offline
Old 11-30-2009, 08:02 PM   #3
Master Electrician
Bubbles's Avatar
Trade: Electrical
Rewards Points: 250
too much tension. it might be working correctly. Try some WD-40 all over the moving parts
Bubbles is offline
Old 11-30-2009, 09:35 PM   #4
Head Grunt
woodchuck2's Avatar
Rewards Points: 2,196
I am going to agree with both above. 1st try lubricating all the moving parts, you will probably find the hinges are rusted and this is why you have problems opening and closing it manually. If the gate moves freely then you may have a bad safety switch as magnettica stated.
woodchuck2 is offline
Old 11-30-2009, 09:54 PM   #5
Trade: plumbing
Thank you for the support but after i lubricated the hinges and moving mechanical parts the problem is still existent. The hinges on the gate work perfectly its the motor in which im worried about. It could be the sensor but why would it be defficult to move the motor when its in nuetral? Would it be something more mechanical?
Old 12-01-2009, 06:20 AM   #6
Head Grunt
woodchuck2's Avatar
Unhook the motor and swing the gate manually to be sure it is the motor. You must also realize that when swinging the gate manually with the motor attached you are also having to overcome the mechanics of the gearbox.
Old 12-01-2009, 02:22 PM   #7
Trade: plumbing
it is for sure the motor. the gat swings freely with it disconnected. So any ideas on what i can do to fix the motor?
Old 12-01-2009, 08:44 PM   #8
Kgmz's Avatar
What led lights on the circuit board are on or off or blinking before and after this happens?
Kgmz is offline
Old 12-01-2009, 10:42 PM   #9
MarcD's Avatar
Trade: Making Everyone Happy
Rewards Points: 75
Did you check the mechanics of it all, bars are not bent in any way. what is the tension on the chain as it starts opening and closing can you see it bounce around does it stay real tight? It could be overtightened also. I dont think its the motor. why would it work halfway and then trip out on the tension? I would try adjusting the gate and making sure the wheels dont stall out in that spot also.
Good luck these things can really suck.
MarcD is offline
Old 03-29-2011, 09:51 AM   #10
jruis101's Avatar
Trade: gate openers
I have a few ideas of what it could be. Please email me at jasonruis123@yahoo.com if you want. My guess is that the internal lock went out so your opener is having to fight its own weight plus the gates. Their is a way to remove this
jruis101 is offline
Old 04-06-2011, 10:00 PM   #11
milanrat's Avatar
Trade: Flooring
I've got the same issue going on. I've swapped main boards, batteries even limit switches, WD40d the whole mechanism and it still happens. I don't want to buy a new motor as they are very expensive. It went through one complete cycle and I thought it was fixed but it started it again. That would lead me to suspect a short somewhere or problem with one of the wires in the bundle?? The motor is making a wierd noise though (never has before) and I may take it apart to clean / lube it. Any other thoughts before I go there?
Thanks
milanrat is offline
Old 04-08-2011, 03:46 PM   #12
The Ultimate Wire Hider
tedanderson's Avatar
Trade: A/V & Home Theater Installation
Rewards Points: 2,116
Originally Posted by milanrat View Post
The motor is making a wierd noise though (never has before) and I may take it apart to clean / lube it. Any other thoughts before I go there? Thanks
Check your mounting hardware to make sure that the pivoting points aren't binding. Sometimes the hardware will sag or come out of alignment and it will need to be bent back into place.
Sometimes if a bracket gets stressed or the motor unit becomes unlevel..or even if the gate post itself becomes out of plumb, it will cause the symptoms that you are describing.
One thing that I learned (the hard way) is that if a gate post is not properly set, over time, it will begin to sag and lean. Depending on the length of the gate, a 1/8" movement of the post can translate to being as much as a 2-inch difference on the far end.
tedanderson is offline
24V gate problems Bob S. Electrical 9 07-26-2011 07:42 PM
Wooden fence gate talk roof-lover Decks & Fencing 9 02-10-2009 06:15 PM
Fence gate on a hill? Apex McGann Decks & Fencing 38 01-26-2009 03:29 PM
Vinyl fence gate posts Danno6102 Decks & Fencing 6 10-20-2008 09:42 PM
