Electrical Wiring
When wiring a house / room what ever is it wise to use 14 guage for lights and outlets ou should I use 12 for outlets and why. Thanks
Re: Electrical Wiring
I always use 12 just for the safety factor.
Trade: underground
12, 13, 14 - whatever it takes
Electrical Contractor
Trade: Electrical
Teetor,
I know this has been beaten to death, and I truly don't want to start a big war. But I am curious as to your opinion. Just how is 12 safer then 14, on a lighting circuit for example?
Trade: Electrical
Exactly my point.
Recessed everywhere, 3 & 4 way switching, dimmers galore. #12 is a bitch with a multi-gang box and 4-ways and dimmers, etc.. Box fill becomes more of an issue as well. No way I'd want 10 recssed on just one switch anyway. Break 'em up and dim 'em all. The difference in circuits is minimal. You might need one or two more 15 amp circuits with everything sized properly. No, it has nothing to do with cost either. Use smaller wire but use more of it.
Chief Toilet Mover
Trade: Bathroom Remodeling
Personally I like 13/5 the best.
Anyways, I have heard the 12 vs 14 stuff from electicians who sub for me and it is the same thing as the stuff I hear from plumbers who sub for me and run gas lines who want to go down to 1/2 inch pipe as fast as possible when I tell them I want it 3/4s. The same excuse is that 1/2 will be fine, which I answer "yeah for this application, but you dead end the homeowner from ever doing anything else. See that fireplace over there? One day he might want to turn it into gas and with this 3/4 instead of 1/2 line running by here all he has to do is tap into this line you are installing, instead of tearing it all out and running 3/4 later." 12/2 gives you more leaway for later, it should be cheaper too when you are running 3 12/2s instead of 5 14/2s. The difference in materials is always negligible, its the labor that kills you. Last edited by Mike Finley; 02-07-2005 at 11:34 PM. |
for residential i have always used #12 romex . for two reasons-
1- before the color code people were mixing 12 and 14( i dont know why but they were) 2-its basicly easy to order and keep in stock, 20 amp br and #12. but speedy pete is - TOTALY correct. he said its not about money and there is where i disagree, there is no way around that. you waist money by installing #12 thats it. i understand mikes point and while i admit to adding a extra conduit or 4 squ box for future use i have never changed the wire size. |
Bigger is not always better. # 12 can be a bitch to work with in tight locations. Which in todays enclosures is everywhere. Just helped my employee troubleshoot a basement room (guy who wired thought he did a great job cus it's all 12) Feeder box had 4 #12s and the wires were so stiff and bulky they were not making good connections. And yes we pulled out every opening in the circuit with smaller boxes #12 and short wires. It's nice to have an appliance thats rated at 15A to blow at 15A and not 20A.
Mark |
I still use emt whenever possible and pull wiring, #12. The problem that I notice is that many seem to consider a switch or recept box the same as a junction or pull box. When this type of wiring is done it can be a bit difficult especially if you are also trying to fit a dimmer switch in there as well.
I don't see a lot of 15A circuits down here and agree that stocking predominantly one size wire/recpt reduces costs even when you use more wire (have to remember the balance of the costs). Returning to the safety issue: With the prevelence of todays electronics, homes have just not been wired for them. I see so many circuits on the verge of overload that I'm really suprised that we are not seeing more fires. Every kids bedroom has at least 6 gang recpt. adapter, computer protector panel and A/V system. Home offices, theaters and kitchens filled with all of the new toys are straining archaic wiring. #12 buys you just a little more insurance. |
Chief Toilet Mover
From reading through all this again it sounds like there are two camps in this issue.
The end users and the people directly serving them say put in 12 guage because it solves the problem and best serve the customer, and the guys installing it are saying not to put it in because they like the easy work of installing 14 guage. |
Yea! The one with a wood burning fireplace.
Mike, I guess that we all know who we are, this thread pretty much died after your post.
Chief Toilet Mover
Didn't mean to offend anybody.
| Electrical License in PA | ABLE1 | Low Voltage | 29 | 10-25-2010 12:20 PM |
| What the worst electrical safety issue you have seen? | SuperiorBuilt | Electrical | 63 | 01-02-2010 12:28 AM |
| fire marshal requires electrical survey | 72chevy4x4 | Electrical | 1 | 02-21-2007 12:07 PM |
| On discouraging DIY electrical work... | mdshunk | Electrical | 52 | 02-18-2006 12:58 AM |
| Garage - Protecting wiring installation | eastment | Electrical | 1 | 11-22-2005 02:52 PM |
