Trade: Handyman
Electrical Problem
Hi I need some help in this matter.
If a plug is installed with the wires reversed. Meaning the wires that suppose to go on the brass is on the silver, would that cause a back feed and to much electicity can come out and burn a tv. We accidently did this...we installed a new plug..customer called stating to much electricity was comming out of the plugs. She had an electrician come out and he said we were the problem. We went back and checked and we found that to be one thing we did wrong. We corrected the problem and we thought okay never again. Leason Learned pay attention and keep away from electicity. We thought ...switching the plug..no big deal $10 fee and we thought customer happy. Customer now wants to sue. Any suggestions. Thanks |
Celtic's #1 Fan
Trade: electrical
Re: Electrical Problem
get a lawyer
LC Australia
Trade: Building
Try to sort it out with them without going to court. Mediate with them and maybe just fix up their tv or whatever because it is usually cheaper for you and less embarassing. It sounds like they want something out of you and are just threatening to sue you and seeing your reaction.
Boy you americans love to sue each other. That's crap! I think us Australians are following suit aswell, sadly. Good luck mate. For all you people in Australia......Enjoy Australia Day Holiday!
"It's better to die on your feet than to live on your knees" |
Time to pony up for a new TV!
Your basic incandescent lamp wouldn't know the difference but anything electronic (amost everything today) can be pretty finicky as you have discovered.
Baltimore Electrician
Trade: Electrician
Did you test the outlet before you left?
Trade: Handyman
We did and it worked fine.
So I'm not sure..wow...this is a sad day...I hope she will not sue.. real hard leason learned. So I guess by your answers..we screwed up.. |
Trade: Squirrel Handler
Does the TV have a polarized plug?, if it does you owe them a new TV, if not you can try and argue the case.
Celtic's #1 Fan
Trade: electrical
he did electrical work illegally. he did electrical work without a license.
i'm sorry, i hope they sue him. |
Re: Electrical Problem |
#10 | |
Trade: underground
Re: Electrical ProblemQuote:
If the TV's power plug can be inserted into an outlet either way (with the blades in either of the 2 positions) then it's absolutely not your fault. If one of the blades is wider, to allow insertion in only one position, then I'd say the customer may have a legitimate beef.
Fortunately I keep my feathers numbered for...for just such an emergency. -Foghorn Leghorn |
DGFVT
Trade: Electrical
Doing electrical work without a licence..Not good
Inserting a two prong plug in a receptacle that is wired wrong should not cause a TV to go south. The reason for a polarized plug is for safety reasons and not necessarily for operational reasons. The internal wiring on an appliance is wired with reference to the grounded conductor (neutral) for safety reasons. It might of been a previous problem on the circuit that caused the TV to go south. The poster did not say why the receptacle was replaced and I question what was wrong before the receptacle was replaced. Carry On! |
Trade: Handyman
Well under California Rules...anything under $500 bucks we can do.
So we did not brake any laws in that respect. The problem is that we hooked up the black wires where the white wires needed to be..so I'm wondering could that be the problem. Or could the house have wiring problems..that now she is trying to pin down on me. Plus one thing that was noticed that there was no ground wire threw out the house. As for the plug why she wanted it changed...She did not mentioned any problems with the plug..just that she would like to have a new plug. Now thinking back....there had to be a problem. |
#13 | |
Electrical Contractor
Trade: Electrical
Are you are actually asking "...if too much electicity can come out..." ?? If you tested the receptacle you would have seen that it was reversed polarity. You obviously did not test it, at least with anything more than a neon lamp tester. You replaced a receptacle. You say there was no ground. Did you use a 3-prong grounded receptacle? If so what did you connect to the ground screw?
Handymen have their place in the marketplace. This is just another example of why doing electrical work is not included in that. Fixing the screen door, hanging a few pictures, installing a new doorknob... fine. Electrical work... eh, not such a good idea.
Union Electrician
Trade: Inside Wireman
Doesn't every electronic device that is plugged in to the wall(like a TV) first run the power through a transformer so the TV can use it?
If so then it don't matter if polarity is reversed, Hell afterall it is alternating current(AC) we're talking about right? I agree with Speedey, why did you change the receptacle? Is someone making you out to be a paycheck, you seem a likely candidate, hahaha |
Trade: CA: Electrical
[quote=Speedy Petey;183237]Are you are actually asking "...if too much electicity can come out..." ??
Speedy didnt you see the post that referenced placing your wires at a downward angle, because electricity flows down hill...........Maybe the TV set is positioned below the receptacle. With no way to stop them electrons no telling what could happen.
#17 | |
Remember CSLB has a stipulation about doing unlicensed work regardless of dollar amount. You must state in writting to the customer that you are not licensed for the work you are performing. Even if it is under $500 they can cause you problems. I would try to remedy the situation and sneak away withan expensive lesson learned. Where are you in CA? Im in Bakersfield |
#18 |
Trade: Handyman
Very true..I'm in South La. You know..I'm aware it was a bad call.,
It was a plug...just one stinking plug..The lady asked me to please change it and I did'nt think it would be a huge problem.. Again..all I charged was a $10 doe'nt ever cover my gas..Specially here in California. But again..if It's my fault..I will deal with it..I definately will try to fix it by paying the damm tv and ofcourse refunding her $10 but I just did not know this can cause such a problem. I think she definately had electrical problems...prior me getting there and I basically took the baite. Oh..and Yes...I did tell her I was NOT a Certified Electrician. Last edited by abonear; 01-25-2007 at 09:14 PM. Reason: need to add one more thing |
#19 | |
By CA Law telling the consumer is not enough to satify the requirement. This applies to any unlicensed work not just Eletricity and not just under $500. CSLB requires written notification before any work starts, it also requires this in advertising. Best of luck |
#20 |
Union Electrician
So then does that make you certifiably resposible? I don't think so.
If a customer hires a handyman to do things, it is basically saying they are too lazy to do them themselves, which in turn relates that this customer couldv'e incorrectly wired this receptacle had they not been so lazy. But California is probably THEE most consumer oriented state(that I know of). But now I'd like to know; you wired this receptacle, burned up a TV, opened the recptacle again, and then realized the white wire goes on the white screw? Or had you always known and just made an honest mistake and somehow had a messed up tester that said it was right? |
| Electrical License in PA | ABLE1 | Low Voltage | 29 | 10-25-2010 12:20 PM |
| What the worst electrical safety issue you have seen? | SuperiorBuilt | Electrical | 63 | 01-02-2010 12:28 AM |
| Well problem | paintr56 | Plumbing | 10 | 02-09-2007 09:20 AM |
| Electrical problem? | Brian | Electrical | 5 | 12-27-2005 11:16 AM |
