Electric Kickspace Heater
Old 01-15-2009, 05:03 PM   #1
mdshunk's Avatar
Anybody know of an electric kickspace heater that has a remote control? I have a pretty rough retrofit, and getting a wall stat is going to be next to impossible (highly finished open concept concrete house). I doubt this particular customer will favor bending over to adjust a unit mounted stat.
The home has hydronic heat, so my other option is to use a strap-on switch on the hydronic loop someplace to turn the heater on when the hydronic is running. This heater is to supliment the hydronic.
mdshunk is offline
Old 01-15-2009, 05:35 PM   #2
Thom
thom's Avatar
Re: Electric Kickspace Heater
The simple on/off would be an X-10 type system. The better way would be with a remote thermostat. Heat-n-glo makes one for use in their gas fireplaces that's a 110V control.
http://www.heatnglo.com/downloads/in...ls/100_906.pdf
thom is online now
Old 01-15-2009, 05:50 PM   #3
mrmike's Avatar
Trade: Electrical & Carpentry
googled this & found an Ouellet 1000 watt OCPU1002BL that says remote included & sold at Northern Tool. I went to their site & in the specs it says remote not included- so if interested I would give them a call. These Ouellets are made in Canada. I have installed the Stelpro heaters from Canada & think they are top notch.............. Mike
mrmike is offline
Old 01-15-2009, 06:00 PM   #4
Service & Repairs
Magnettica's Avatar
Trade: Electrician
I assume they have to make them. There are plenty of window A/C units with remotes so there has to be something for heat too.
Magnettica is offline
Old 01-15-2009, 06:08 PM   #5
mickeyco's Avatar
Trade: Squirrel Handler
I think he's looking for a wireless remote control, I think the one you are referring to is a remote control in that it is located away from the unit but wired, but I'd check it out to be sure.
Westinghouse makes a thermostatic, wireless, ceiling fan control that can be used with a relay to control a heater, maybe a wireless fireplace controller.
mickeyco is offline
