Electric Baseboard Circuit Help Needed
We have two very old electric baseboard heaters in our basement that are rusty and generally just ugly. Since I'm painting and recarpeting down there and needed to remove them I plan on replacing them with new equipment. After scaring myself by allowing the white wire to touch the metal case and weld itself there I realized the wiring setup they have wasn't what I thought it was. I'm hoping you can help me understand this. I included a diagram of what they have wired up.
The reason I scared myself and didn't realize they were still live is because the thermostat was off and I also checked between the white and gray wires at the heater for voltage. I got 0.0 volts there when I expected to see 220-240. Measuring from the white to the copper I get 120 volts. Are these wired as 240 volts if I'm not seeing 240 from the white to grey? I assumed that 240 volts would be there and the black and grey wires were out of phase. Regular household wiring (120V) isn't an issue for me but I get a little confused when it comes to 240. I understand now how the wire was live even though the thermostat was off. Can electric baseboard heaters be installed OVER carpet? The carpet wouldn't be touching the heating element but I want to make sure they are either high enough away from the carpet or I don't put carpet under them. Thanks! |
Chief Toilet Mover
Trade: Bathroom Remodeling
Re: Electric Baseboard Circuit Help Needed
You might want to look at these instead of base board. They look like a air register in the wall and work pretty nicely, this is what I recommend in situations like yours.
http://www.cadetco.com/show_product.php?prodid=1001 |
Those would work really well but I don't believe I have the depth in the wall. The walls are just panel stubbed out from block walls by a 1x2 or something similar. Cadetco makes a baseboard heater like we have down there so I planned to just go with that. We have NEVER used the ones down there (due to age) and these would be used VERY rarely.
Nevermind.... I'm an idiot. I will see 240 volts from white to grey once I close the thermostat. Duh.....
ET
I prefer to mount electric baseboard heaters above the baseboard at a minimum. 8 inches to the bottom is generally a good place. Never in a closet, never under draperies of any kind. Never behind a door. Use common sense of course.
Personally I avoid them entirely whenever possible. As far as cost for comfort, there is nothing less efficient or more costly than a convective electric baseboard heater. A hand held blow dryer would do a more efficient job of heating an area than a baseboard hands down and at half the wattage. |
Chief Toilet Mover
Rats, too bad about the walls.
Eric T - it is all relative to where you live and your heating costs. If you are in the NE electric heat can be a killer, it isn't necessarily true country wide. We are currently seeing our natural gas prices double from 2002 out here in the west due to the new pipelines that went on line, allowing our excess natural gas to be piped out of our area to places willing to pay more for causing our supply to go down and the price to go up. |
#7 | |
Trade: underground
Re: Electric Baseboard Circuit Help NeededQuote:
Fortunately I keep my feathers numbered for...for just such an emergency. -Foghorn Leghorn |
| New OSHA standard | OsNap | Health & Safety | 8 | 01-08-2010 09:19 PM |
| Recessed baseboard | Maplehead | Finish Carpentry | 12 | 03-04-2007 01:13 PM |
| Electric Baseboard Heaters available | LNG24 | Contractor Swap | 0 | 02-05-2006 01:44 AM |
| Baseboard Electric..conversion w/ gas | sprinklerguy | HVAC | 5 | 01-01-2006 12:38 AM |
| Consolidated Diesel Electric Genset | thecrose12 | Electrical | 0 | 03-08-2004 04:34 PM |
